2 dht22
hello everyone, I am very very beginner. Please can you tell me if you can view in the dashboard cayenne two sensors dht22 connected to arduino?
Thanks so much
Ilario
You can have a look at this Double Temperature, rain, humidity on LCD with ESP8266
@shramiksalgaonkar that looks like the blynk library.
You can use my project as a base. Swap out the libraries for esp with your board/shield and then duplicate code to read another dht11 sensor. Let me know if you have any problems. Post your code and I’ll see if I can help.
Many thanks! I’ll still ask for help to remove the part related to the display and add the code to connect the board to Cayenne.
thank you very much, let’s see if I understand something. Surely I will still need your help.
@adam i shared the above link for using two DHT22.
@ilario.quinson as adam stated you have to use the new MQTT library which can be found in adam’s project.
Hello everyone, I modified the sketch of shramiksalgaonka. First problem I can not find the CayennEthernet.h library in the Arduino IDE libraries.
where am I wrong? thank you so much
#include <DHT.h>                              //senzor
#define DHTPIN 2
#define DHTPINB 3
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
DHT dhtb(DHTPINB, DHTTYPE);
float hum, temp;
float humB, tempB;
#include <CayenneEthernet.h>
char token[] = "AuthenticationToken";
  dht.begin();
  Cayenne.begin(token, ssid, password);       //Cayenne
void loop(){
// display.command( PCD8544_FUNCTIONSET | PCD8544_POWERDOWN);
  hum = dht.readHumidity();
  temp = dht.readTemperature();
  humB = dhtb.readHumidity();
  tempB = dhtb.readTemperature();
CAYENNE_OUT(V0)
  Cayenne.virtualWrite(V0, dht.readTemperature(true));
CAYENNE_OUT(V1)
  Cayenne.virtualWrite(V1, dht.readHumidity());
CAYENNE_OUT(V2)
  Cayenne.virtualWrite(V2, dhtb.readTemperature(true));
CAYENNE_OUT(V3)
  Cayenne.virtualWrite(V3, dhtb.readHumidity());
you need to use new cayenne MQTT library. https://github.com/myDevicesIoT/Cayenne-MQTT-Arduino
Thanks!
Do I have to include libraries Cayenne-MQTT-Arduino even if I do not use wifi but shield ethernet?
depending on the connection you have to include the appropriate library. here you will see the different support connection https://github.com/myDevicesIoT/Cayenne-MQTT-Arduino/tree/master/examples/Connections
Many thanks!
Hi everyone, I just can not configure anything. Let’s try to make a path step by step.
I log in to my account, I choose arduino uno, the shield 5100. the portal generates a sketch that I copy and paste into the IDE of arduino, shortly after the portal should recognize my board.
I install the Cayenne LPP and CayenneMQTT libraries.
First problem compiling the sketch brings me many errors, load the same sketch and nothing seems to happen, except that I get the email from cayenne that a new device has been added.
Any suggestion?
thanks
#14
can you share the code, screenshot of dashboard and error from the serial monitor.
#15
n file included from /home/pi/Arduino/libraries/CayenneMQTT/src/CayenneMQTTEthernetClient.h:21:0,
from /home/pi/Arduino/libraries/CayenneMQTT/src/CayenneMQTTEthernet.h:25,
from /home/pi/Arduino/sketch_jul15c/sketch_jul15c.ino:14:
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneArduinoMQTTClient.h: In member function ‘void CayenneArduinoMQTTClient::connect()’:
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneArduinoMQTTClient.h:58:63: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneMQTTClient/CayenneMQTTClient.c: In function ‘CayenneMQTTPublishDataInt’:
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneMQTTClient/CayenneMQTTClient.c:135:2: warning: implicit declaration of function ‘itoa’ [-Wimplicit-function-declaration]
itoa(value, str, 10);
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneMQTTClient/CayenneMQTTClient.c: In function ‘CayenneMQTTPublishDataUInt’:
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneMQTTClient/CayenneMQTTClient.c:158:2: warning: implicit declaration of function ‘utoa’ [-Wimplicit-function-declaration]
utoa(value, str, 10);
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneMQTTClient/CayenneMQTTClient.c: In function ‘CayenneMQTTPublishDataLong’:
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneMQTTClient/CayenneMQTTClient.c:181:2: warning: implicit declaration of function ‘ltoa’ [-Wimplicit-function-declaration]
ltoa(value, str, 10);
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneMQTTClient/CayenneMQTTClient.c: In function ‘CayenneMQTTPublishDataULong’:
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneMQTTClient/CayenneMQTTClient.c:204:2: warning: implicit declaration of function ‘ultoa’ [-Wimplicit-function-declaration]
ultoa(value, str, 10);
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneMQTTClient/CayenneMQTTClient.c: In function ‘CayenneMQTTPublishDataDouble’:
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneMQTTClient/CayenneMQTTClient.c:227:2: warning: implicit declaration of function ‘dtostrf’ [-Wimplicit-function-declaration]
dtostrf(value, 5, 3, str);
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneUtils/CayenneDataArray.c: In function ‘CayenneDataArrayAddInt’:
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneUtils/CayenneDataArray.c:87:2: warning: implicit declaration of function ‘itoa’ [-Wimplicit-function-declaration]
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneUtils/CayenneDataArray.c: In function ‘CayenneDataArrayAddUInt’:
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneUtils/CayenneDataArray.c:105:2: warning: implicit declaration of function ‘utoa’ [-Wimplicit-function-declaration]
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneUtils/CayenneDataArray.c: In function ‘CayenneDataArrayAddLong’:
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneUtils/CayenneDataArray.c:123:2: warning: implicit declaration of function ‘ltoa’ [-Wimplicit-function-declaration]
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneUtils/CayenneDataArray.c: In function ‘CayenneDataArrayAddULong’:
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneUtils/CayenneDataArray.c:141:2: warning: implicit declaration of function ‘ultoa’ [-Wimplicit-function-declaration]
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneUtils/CayenneDataArray.c: In function ‘CayenneDataArrayAddDouble’:
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneUtils/CayenneDataArray.c:159:2: warning: implicit declaration of function ‘dtostrf’ [-Wimplicit-function-declaration]
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneUtils/CayenneUtils.c: In function ‘buildSuffix’:
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneUtils/CayenneUtils.c:88:15: warning: assignment discards ‘const’ qualifier from pointer target type
topicString = COMMAND_STRING;
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneUtils/CayenneUtils.c:91:15: warning: assignment discards ‘const’ qualifier from pointer target type
topicString = DATA_STRING;
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneUtils/CayenneUtils.c:94:15: warning: assignment discards ‘const’ qualifier from pointer target type
topicString = RESPONSE_STRING;
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneUtils/CayenneUtils.c:97:15: warning: assignment discards ‘const’ qualifier from pointer target type
topicString = SYS_MODEL_STRING;
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneUtils/CayenneUtils.c:100:15: warning: assignment discards ‘const’ qualifier from pointer target type
topicString = SYS_VERSION_STRING;
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneUtils/CayenneUtils.c:103:15: warning: assignment discards ‘const’ qualifier from pointer target type
topicString = SYS_CPU_MODEL_STRING;
/home/pi/Arduino/libraries/CayenneMQTT/src/CayenneUtils/CayenneUtils.c:106:15: warning: assignment discards ‘const’ qualifier from pointer target type
topicString = SYS_CPU_SPEED_STRING;
#17
Steps:
1. Set the Cayenne authentication info to match the authentication info from the Dashboard.
2. Compile and upload the sketch.
3. A temporary widget will be automatically generated in the Cayenne Dashboard. To make the widget permanent click the plus sign on the widget.
char username[] = "";
char password[] = "";
char clientID[] = "";
CAYENNE_OUT_DEFAULT()
  //Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
#18
I am delete device from cayenne site and try with new configuration.
#19
is this the entire serial monitor output?
#20
The first post is the error message that returns IDE at the time of compilation
Below is the text that appears in the serial monitor
[0] 168.0.7
[1464] Connecting to mqtt.mydevices.com:1883
[1762] Connected
[0] MAC: FE-31-AE-F-3F-9F
[513] IP: 192.168.0.7
[514] Connecting to mqtt.mydevices.com:1883
[834] Connected
#21
this means you have successfully connected to cayenne server. Add #define CAYENNE_DEBUG to see the entire output.
