2 dht22
this code reads 5 parameters from the DTH22 namely
  1. humidity using float h = dht.readHumidity();
  2. temperature in Celsius using float t = dht.readTemperature();
  3. temperature in Fahrenheit using float f = dht.readTemperature(true);
  4. heat index in Celsius using float hif = dht.computeHeatIndex(f, h);
  5. heat index in Fahrenheit, using float hic = dht.computeHeatIndex(t, h, false);
Next this value are published/send to cayenne using:
Cayenne.virtualWrite(DTH_hum_Virtual_Channel, h, "rel_hum", "p");
Cayenne.virtualWrite(DTH_tempC_Virtual_Channel, t, "temp", "c");
Cayenne.virtualWrite(DTH_tempF_Virtual_Channel, f, "temp", "f");
Cayenne.virtualWrite(DTH_hif_Virtual_Channel, hif, "temp", "f");
Cayenne.virtualWrite(DTH_hic_Virtual_Channel, hic, "temp", "c");
Now remove whichever you donā€™t want from the code.
Thank you! I duplicated the part of code for reading the sensors, but I had not seen this part that I did not duplicate.
#define DTH_hum_Virtual_Channel 1
#define DTH_tempC_Virtual_Channel 2
#define DTH_tempF_Virtual_Channel 3
#define DTH_hic_Virtual_Channel 4
#define DTH_hif_Virtual_Channel 5
thanks for your patienceā€¦
you also need to duplicate this part with different name and channel number.
It works!!! thank you very much to all the people who have had the desire and the patience to help me.
image![image|663x404]
Grazie
you can change the name of the widget by clicking on the clog wheel for setting on the widget.
Hello everyone, my sketch for two dht22 has stopped going, have you changed something that prevents you from using 2 sensors on the same arduino?
Thank you
add #define CAYENNE_DEBUG in your code and check the issue in your serial monitor.
Thanks for the answer, I have two dht22 and if I change the pins the result does not change I only see the pin 2, But the really strange thing is that suddenly it stopped working, so I thought you had taken away the possibility of having two sensors on the same board.
Steps:
1. Set the Cayenne authentication info to match the authentication info from the Dashboard.
2. Compile and upload the sketch.
3. A temporary widget will be automatically generated in the Cayenne Dashboard. To make the widget permanent click the plus sign on the widget.
#define CAYENNE_DEBUG       // Uncomment to show debug messages
//DTH
#include "DHT.h"
//#define DHTPIN 2//
//#define DHTTYPE DHT22
DHT dht(2, DHT22);
DHT dht7(7,DHT22);
#define DTH7_hum_Virtual_Channel 6
#define DTH7_tempC_Virtual_Channel 7
#define DTH7_tempF_Virtual_Channel 8
#define DTH7_hic_Virtual_Channel 9
#define DTH7_hif_Virtual_Channel 10
unsigned long lastMillis_dht = 0;
char username[] = "";
char password[] = "";
char clientID[] = "";
    //DTH
  dht.begin();
  //DTH
  if (millis() - lastMillis_dht > 10000) {
    lastMillis_dht = millis();
    // Reading temperature or humidity takes about 250 milliseconds!
    // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
    // Read temperature as Fahrenheit (isFahrenheit = true)
    if (isnan(h) || isnan(t) || isnan(f)) {
      Serial.println("Failed to read from DHT sensor!");
      return;
    // Compute heat index in Fahrenheit (the default)
    // Compute heat index in Celsius (isFahreheit = false)
    Serial.print("Humidity: ");
    Serial.print(h);
    Serial.print(" %\t");
    Serial.print(t);
    Serial.print(" *C ");
    Serial.print(f);
    Serial.print(" *F\t");
    Serial.print("Heat index: ");
    Serial.print(hic);
    Serial.print(hif);
    Serial.println(" *F");
    //dht7
    float h7 = dht7.readHumidity();
    float t7 = dht7.readTemperature();
    float f7 = dht7.readTemperature(true);
    if (isnan(h7) || isnan(t7) || isnan(f7)) {
      return;
    float hif7 = dht7.computeHeatIndex(f, h);
    float hic7 = dht7.computeHeatIndex(t, h, false);
    Serial.print(h7);
    Serial.print(t7);
    //Serial.print(f7);
    Serial.print(hic7);
    Serial.print(hif7);
    Cayenne.virtualWrite(DTH7_hum_Virtual_Channel, h, "rel_hum", "p");
    Cayenne.virtualWrite(DTH7_tempC_Virtual_Channel, t, "temp", "c");
    Cayenne.virtualWrite(DTH7_tempF_Virtual_Channel, f, "temp", "f");
    Cayenne.virtualWrite(DTH7_hif_Virtual_Channel, hif, "temp", "f");
    Cayenne.virtualWrite(DTH7_hic_Virtual_Channel, hic, "temp", "c");
add dht7.begin(); in void setup()
Thank you so much! It remains to be seen why that line has been deleted!
