What is your agent version? If you click the settings wheel in the top right of the dashboard then click configure you can see the agent verson listed there.
I turned mine on yesterday and mine seems to be pushing the limits for ram too. @bestes I remember there being a bug a while back but it looks like was fixed. Maybe it’s back again?
I am having the same problem. I have to reset every 12-24 hours. I’m also noticing a very large log file building. I haven’t checked to see if that’s normal or not yet.
Are you using by anychance Adafruit ILI9341 library or DS18b20 temp sensor? I have the same problems, getting rid of the ILI9341 was the key (display.clear() has a memmory leak)
I do have 3 dallas 1 wire temp sensors.
well i had 3.
one is disconnected right now but all 3 are still showing in the dashboard.
could that be the issue?
from what i see there are two instances of python3 running sucking up the ram according to TOP.
could be a memory leak in some module?
It’s a fresh install of latest raspbian followed by a cayenne install and nothing else.
I can confirm I have this bug as well but the Cayenne team has not yet confirmed it so it’s not being worked on. Unfortunately there isn’t an estimate on when they will get to it yet, just hang in there. Here is a workaround for the growing log the last time this bug was around: Bug Filed on 12-21-2015: SD become full in few hours - #8 by adam unfortunately the ram issue will need a reboot.
I too noticed this issue. I did a fresh install of Raspbian last night followed by the Cayenne installation. At first the RAM use was around 30%, but today it’s back to around 95%.
Hi all, I can confirm we’re aware of this issue (I see it on one of my own Pis), and it’s a top development item to be fixed. I’ll update as soon as I know more about a fix.
