A virtual button without a physical button
Im trying to make my RGB LED Sliders(RED GREEN AND BLUE) all turn on at the same time and turn off at the same time without a physical button. Is this possible i’ve tried setting triggers but it doesn’t work. Please help
Hello Sir,
Can you give more information about the board that you use and also the configuration?
@freddyisdabest2 can you provide more detail on what you want to achieve and what is the problem with triggers?
// If you’re not using the Ethernet W5100 shield, change this to match your connection type. See Communications examples.
#include <CayenneEthernet.h>
#define LED_VIRTUAL_PIN1 1
#define LED_DIGITAL_PIN1 3
#define LED_VIRTUAL_PIN2 2
#define LED_DIGITAL_PIN2 5
#define LED_VIRTUAL_PIN3 3
#define LED_DIGITAL_PIN3 6
char token = “AuthenticationToken”;
Cayenne.begin(token);
CAYENNE_IN(LED_VIRTUAL_PIN1)
int currentValue1 = getValue.asInt(); // 0 to 255
analogWrite(LED_DIGITAL_PIN1, currentValue1); // analogWrite accepts a value from 0 to 255
CAYENNE_IN(LED_VIRTUAL_PIN2)
analogWrite(LED_DIGITAL_PIN2, currentValue1); // analogWrite accepts a value from 0 to 255
CAYENNE_IN(LED_VIRTUAL_PIN3)
analogWrite(LED_DIGITAL_PIN3, currentValue1); // analogWrite accepts a value from 0 to 255
This is my code.
Im trying to turn on all of the sliders by using a custom widget button. But i dont know how to.
turn all to full brightness??
Yes
All 3 of them to full brightness
this can be done without using triggers but by programming.
set your custom widget button to virtual pin 4.
CAYENNE_IN(V4)
if (currentValue =1)
digitalWrite(LED_DIGITAL_PIN1, HIGH);
digitalWrite(LED_DIGITAL_PIN2, HIGH);
digitalWrite(LED_DIGITAL_PIN3, HIGH);
else
digitalWrite(LED_DIGITAL_PIN1, LOW);
digitalWrite(LED_DIGITAL_PIN2, LOW);
digitalWrite(LED_DIGITAL_PIN3, LOW);
Alright Thank you sir!
You are very fast :slight_smile:
@ognqn.chikov :wink:
Uhh slight problem the light just stays on and it doesn’t turn off :frowning:
even when you deselect(press again) the custom widget button??
Yeap
did you add the missing } at last in the code i gave??
CAYENNE_IN(V4)
else
Yes i did
use serial.println to check if you are receiving 1 or 0.
CAYENNE_IN(V4)
Serial.println(“on”);
else
Serial.println(“off”);
i only receive on and not off even though i clicked the button off it still says on on the serial monitor.
[5001] Connecting to arduino.mydevices.com:8442
[5754] Ready (ping: 265ms).
on
on
on
CAYENNE_IN(V4)
if (currentValue ==1)
else
try this code now
Nice it works now thank you so much.
