About the Bugs / Issues category
Please report bugs and any other strange behavior here.
Developing software is a dynamic process and we strive to constantly and consistently improve what we do. Report the issue and it will be fixed, we promise :smile:
We have provided a template for you when you create the topic. Following the template and giving us as much information as possible will help us quickly fix it.
I get every minute a device notification. Since this happend I deleted all from the scheduler, all projekts and all devices from the account. But I still get every minute a device notivication. I use an arduino with wifi shield. I powered it off. But the problem is not solved.
Hi, I am using Pi 2model B/Pi3/PiZero/esp8266
Web and Android
Since updates all devices behaving erratically + triggers stopped working. I have followed instructions on force stop and clear cache, for a few days now I have to log out then in again. I noticed on start up now blank screen for a minute before widgets appear without loading sequence.
I now cannot set new triggers as drag and drop has stopped on Web-dashboard.
Regards Greg.
