Tried to delete the storage tile "sensor"which I was unable to do, after nothing happened I pressed reset dashboard and some of the tiles changed from values to trends and others from values to guage.
Not sure if it’s related to the reset button or trying to delete the storage tile
Good to see you again! I changed your post to an ‘Ideas / Suggestions’, since it’s a really good idea that we should allow! So, right now, you can only delete a widget that you add. Since the Storage tile sensor is from the Pi itself, we haven’t allowed a delete function. However, we have plans to allow you to hide widgets.
The Reset Dashboard Button Resets all of the widgets to a default widget, thus messing up how you originally organized your widget. Perhaps a pop up explaining the function of the button would have explained this better so you knew what happened before you clicked it?
We’re actually changing the design of the dashboard to allow you to create multiple dashboard for various ‘Projects’. So in this sense, you’ll be able to add any widget you’d like to a specific ‘Project’ dashboard, and also ensure that any unwanted widgets are not on the dashboard.
