Analog Sensor Custom Values for Triggers
Thank you in advance for taking the time to let us know about your Ideas. We truly value your input and discuss each Suggestion as a team. It would be most helpful if you could include a use case for your Idea (how it will solve a problem, or add to the usefulness of Cayenne as a proto-typing solution). Thanks!
I need to be able to use decimals in my triggers using generic analog inputs. I am monitoring VCC voltage from an ESP-12f and need to send an alert if the voltage drops below 2.7v.
Perhaps just stale up the input voltage ?
I do this in a situation where a remote instrument send’s the battery voltage over a long distance serial radio link so keep overhead down with data = a simple byte value so I do 10ths of a volt.
37 = 3.7 volts etc
~ Andrew
