Analog values updating ok but not triggering High and Low alarms
I am using an 8266 to send an analog value 0 to 1024 on channel 0, just using a pot. The value is updating ok on the overview page. i created some triggers to be sent via text and email and it seemed intuitive to set them up but none are working. I created high and low set-points and a threshold of 500. I also set an online/offline trigger. I can move the pot but no alerts are sent. What am i doing wrong?
//#define CAYENNE_DEBUG
int analogPin = A0;
int pot = 0;
char ssid[] = “cleo****”;
char wifiPassword[] = “Bulls***”;
char username[] = “9d5fb8c0-bf04-11e7-993a-9b80361bb***”;
char password[] = “d50e5910dfd7068eae12858a7b3e47272086f***”;
char clientID[] = “b8af2570-bf04-11e7-b1f7-559b31b83***”;
unsigned long lastMillis = 0;
pot = analogRead(analogPin); // read the input pin
// //Publish data every 10 seconds (10000 milliseconds). Change this value to publish at a different interval.
if (millis() - lastMillis > 1000)
	lastMillis = millis();
// //Write data to Cayenne here. This example just sends the current uptime in milliseconds.
Cayenne.virtualWrite(0, pot, “analog_sensor”, “null”);
Serial.println (pot);
// //Some examples of other functions you can use to send data.
// //Cayenne.celsiusWrite(1, 22.0);
// //Cayenne.luxWrite(2, 700);
// //Cayenne.virtualWrite(3, 50, TYPE_PROXIMITY, UNIT_CENTIMETER);
CAYENNE_IN_DEFAULT()
@pughlabs welcome to cayenne community.
there is problem with triggers using MQTT. @rsiegel and @bestes tagging for this bug,
one alternative can be use a regular connection. add a custom guage widget with virtual pin 1.
#include "CayenneDefines.h"
char token[] = "";
char ssid[] = "";
char password[] = "";
CAYENNE_OUT(V1)
  Cayenne.virtualWrite(1, pot);
Could you explain a little more detail on the bug you’re seeing here? I’ve run a test with some MQTT data (very contrived, just publishing numbers counting upward) and each time a trigger threshold is hit, it’s firing OK for me.
@shramiksalgaonkar I should have told you we have made a few fixes for triggers so may be something else :stuck_out_tongue:
oops sorry @bestes and @rsiegel.
