Android app isue
Hello. I have strange issue with my device. I am using Arduino UNO with W5100 ethernet shield. I try control 2 relays through android dashboard. From web it works great, but in mobile app it doesnt works.
did you added the device on dashboard using Bring Your Own Thing?
No, i added it through standard process. (Devices & Widgets).
can you add a new device using Bring Your Own Thing? go to add new > device/widget > bring your own thing > take note of the MQTT creddential and then follow the same procedure you used for previous device.
It works!!! Thank you. Why does it work this way?
there is some know issue with it. team is working on solving.
