Arduino Documentation issues
The problem with cut and paste - is that you end up with residual information from the previous document - as you can see from the example below. There are many other examples within the document - and I assume this will be updated eventually.
The following snapshot was taken from the Arduino Documentation:
http://www.cayenne-mydevices.com/docs/#arduino-arduino
Hi Scott,
Welcome to the Cayenne community :slight_smile:
Yikes! This will be fixed, thank you for reporting!
Thanks for reporting this. I’ve made the fix in the docs. If you still have the page open, you may have to refresh to see it updated.
