hi guys, I always go ahead with my projects, but now that I have installed the part of the garden I am in trouble with the sketch for irrigation
I would like to be able to manage irrigation times,
type 10 minutes zone1, stop, 10 minutes zone2, stop etc.
I was thinking with the time function, but I’m not an expert,
or with cilci if then else
or with for loops,
help me
example
for [ciclo1=0;CICLO<=100;ciclo1++];
digitalWirte (1,HIGH);]
for then arduino is disconed to remain in loop with the cycle for …
Help me
you want zone1 to remain ON for 10 minutes and then OFF for rest of the period?
Can you share the code you have so far?
char username[] = "";
char password[] = "
char clientID[] = "
#define RELAY_DIGITAL_PIN 3
#define RELAY_DIGITAL_PIN2 4
#define RELAY_DIGITAL_PIN3 5
#define RELAY_DIGITAL_PIN4 7
int luminosita; //Il valore letto dalla fotoresistenza
int umidita;
int sensorepioggia;
unsigned long lastMillis=0;
int CICLO=1;
pinMode(RELAY_DIGITAL_PIN, OUTPUT);
pinMode(RELAY_DIGITAL_PIN2, OUTPUT);
pinMode(RELAY_DIGITAL_PIN3, OUTPUT);
pinMode(RELAY_DIGITAL_PIN4, OUTPUT);
delay(100);
digitalWrite(RELAY_DIGITAL_PIN, HIGH);
digitalWrite(RELAY_DIGITAL_PIN2, HIGH);
digitalWrite(RELAY_DIGITAL_PIN4, HIGH);
digitalWrite(RELAY_DIGITAL_PIN3, HIGH);
Cayenne.virtualWrite(3, 0);
Cayenne.virtualWrite(4, 0);
Cayenne.virtualWrite(5, 0);
Cayenne.virtualWrite(6, 0);
Cayenne.virtualWrite(12,0);
Cayenne.virtualWrite(11, 0);
Cayenne.virtualWrite(10, 0);
CAYENNE_LOG("Sync data");
Serial.print("valore del ciclo =");
Serial.println(CICLO);
pinMode(A0, INPUT);
pinMode(A1, INPUT);
pinMode(8, INPUT);
pinMode(2,INPUT);
lastMillis = millis();
luminosita = digitalRead(2); //Lettura della luminosità
umidita = analogRead(A1);
Serial.print("luminosita = ");
Serial.println(luminosita);
Serial.print("umidita = ");
Serial.println(umidita);
sensorepioggia=digitalRead(8);
Serial.print("sensore pioggia =");
Serial.println(sensorepioggia);
Serial.print("Finito invio");
CAYENNE_OUT_DEFAULT()
Cayenne.luxWrite(1, luminosita);
Cayenne.virtualWrite(2, umidita,TYPE_RELATIVE_HUMIDITY);
Cayenne.virtualWrite(8, sensorepioggia);
//sensorepioggia=digitalRead(10);
//Serial.println(sensorepioggia);
//Cayenne.virtualWrite(10, sensorepioggia);
CAYENNE_IN(3)
if (currentValue == 0) {
} else {
digitalWrite(RELAY_DIGITAL_PIN, LOW);
CAYENNE_IN(4)
} else {
digitalWrite(RELAY_DIGITAL_PIN2,LOW);
CAYENNE_IN(5)
} else {
digitalWrite(RELAY_DIGITAL_PIN3, LOW);
CAYENNE_IN(6)
} else {
digitalWrite(RELAY_DIGITAL_PIN4, LOW);
CAYENNE_IN(10)
if (currentValue == 0) { Cayenne.virtualWrite(10, 0);
} else {Cayenne.virtualWrite(10,1);
Cayenne.virtualWrite(11,1);
Cayenne.virtualWrite(21,1);
delay(100);
for(int ciclo1=0;ciclo1<=CICLO;ciclo1++){
digitalWrite(RELAY_DIGITAL_PIN2, LOW);
Serial.println("sto facendo il ciclo 1");
Serial.println(ciclo1);
delay(1000);
Cayenne.virtualWrite(21,0);
Cayenne.virtualWrite(22,1);
for(int ciclo2=0;ciclo2<=CICLO;ciclo2++){
Serial.println("sto facendo il ciclo 2");
Serial.println(ciclo2);
delay(1000);
Cayenne.virtualWrite(22,0);
Cayenne.virtualWrite(23,1);
for(int ciclo3=0;ciclo3<=CICLO;ciclo3++){
Serial.println("sto facendo il ciclo 3");
Serial.println(ciclo3);
delay(1000);
Cayenne.virtualWrite(23,0);
delay(100);
Serial.println("finito ciclo e update valore");
CAYENNE_IN(12)
CICLO=(currentValue*10);
CAYENNE_IN_DEFAULT()
you want to change this code? in which you want RELAY_DIGITAL_PIN2 to remain ON for 10 minutes then OFF. then RELAY_DIGITAL_PIN to remain ON for 10 min and OFF?
yes
what is the value of CICLO? from your code it is 1.
P.S you have used slider to set CICLO value.
@Massimotruglio83 this basic structure to turn ON and OFF relays for x time.
if (x == 1)
if (millis() - lastMillis > y && a == 1)
digitalWrite(5, HIGH);
b = 1;
lastMillis1 = millis();
digitalWrite(5, LOW);
a = 0;
if (b == 1)
if (millis() - lastMillis1 > y)
digitalWrite(6, HIGH);
b = 0;
x = 0;
CAYENNE_IN(10)
x = getValue.asInt(); // 0 to 1
a = 1;
CAYENNE_IN(12)
z = getValue.asInt(); // 0 to 1
y = z * 1000;
luminosita = 1
umidita = 235
sensore pioggia =0
Finito invio
valore millis =18718
valore lastmillis =0
valore differenza tempo =18775
inizio ciclo da =10
[19099] ⸮⸮S3⸮
⸮/⸮?⸮O⸮⸮⸮⸮⸮⸮0⸮⸮r⸮⸮/⸮?⸮O⸮_⸮⸮⸮⸮N3<⸮d⸮r⸮⸮⸮⸮⸮⸮e⸮⸮/⸮?⸮O⸮_⸮⸮⸮⸮⸮0⸮⸮⸮⸮ ⸮0⸮⸮⸮⸮⸮0⸮⸮ ⸮m⸮⸮⸮⸮⸮e⸮⸮⸮⸮⸮⸮⸮⸮*⸮7⸮C⸮[⸮⸮⸮⸮⸮2+<⸮3K\⸮⸮0⸮⸮⸮⸮⸮⸮2+<*⸮⸮⸮⸮⸮⸮⸮en⸮⸮⸮⸮⸮e ⸮0⸮@⸮Q⸮⸮⸮⸮J1+<⸮3K⸮,⸮,*⸮⸮⸮⸮⸮⸮⸮e⸮⸮⸮⸮0⸮⸮⸮⸮⸮⸮2 ⸮0⸮@⸮Q⸮⸮J1⸮3⸮
⸮p⸮*⸮+⸮⸮⸮⸮⸮⸮⸮⸮,?O^⸮⸮MAC: FE-36-22-58-D9-9F
[514] IP: 192.168.1.210
[515] Connecting to mqtt.mydevices.com:1883
[871] Connected
valore del ciclo =1
why?!
i dint get what you are saying. can you provide more detail.
int umidita;
int sensorepioggia;
int CICLO=1;
int x=0;
int a=0;
int b=0;
int c=0;
unsigned long lastMillis1=0;
unsigned long lastMillis2=0;
unsigned long lastMillis3=0;
int y=0;
pinMode(A0, INPUT);
pinMode(A1, INPUT);
pinMode(8, INPUT);
pinMode(2,INPUT);
if (x == 1)
b = 1;
a = 0;
Serial.println("iniziato Ciclo If");
if (b == 1)
if (millis() - lastMillis2 > y && b == 1)
b = 0;
lastMillis2 = millis();
c =1;
Serial.println("secondo step");
if (c == 1)
if (millis() - lastMillis3 > y && c == 1)
c = 0;
lastMillis3 = millis();
Serial.println("terzo step");
Cayenne.virtualWrite(10,0);
Cayenne.virtualWrite(11,0);
Serial.println("fine ciclo irrigazione");
Cayenne.virtualWrite(1, luminosita);
Cayenne.virtualWrite(2, umidita,TYPE_RELATIVE_HUMIDITY,UNIT_PERCENT);
luminosita = !digitalRead(2); //Lettura della luminosità
Serial.println("Finito invio");
CAYENNE_IN(3)
} else {
CAYENNE_IN(4)
} else {
CAYENNE_IN(5)
} else {
CAYENNE_IN(6)
} else {
CAYENNE_IN(10)
digitalWrite(RELAY_DIGITAL_PIN , LOW);
a = 1;
Serial.println(" inizio ciclo da =");
Serial.println(y);
CAYENNE_IN(12)
CICLO = getValue.asInt(); // 0 to 1
y = CICLO * 1000;
Serial.print(" Valore variabile ciclo =");
Serial.println(y);
the code works for example on esp8266 to perfection. with arduino and the w5100 freezes, while with the w5500 no. because?!!
‘#define CAYENNE_DEBUG’ add this line and see what is the output in serial monitor.
Simple.
It freezes… it doesn’t do anything anymore
@Massimotruglio83 i tested your code and it worked without any problem on my arduino uno and w5100 for 10 minutes.
i hope you are not adding this code. pin 10 11 12 13, they are reserved for communication.
forgive me, where did you see the pins 10,11,12 engaged?
It’s commented out in your code, he added a snip in his post
