Arduino Mega+ ethernet shield not connecting to Cayenne dashboard
I have connected Arduino mega with ethernet shield W5100 through an ethernet cable and usb to serial cable to laptop
I have installed Cayenne libraries, selected the correct port and board.
Through Cayenne dashboard- selected Arduino Mega-shield W5100-sketch copy pasted using correct authorization token.
Compiled the code and uploaded, but still Arduino does not get connected to the Cayenne dashboard.
I get serial output as [0] MAC: FE-DB-D6-E2-9F-C5
[0] Getting IP…
[60451] DHCP Failed!
How do i solve this? pls help. Its urgent. Thanks in advance
Hello and welcome to Cayenne community,
First of all - restart your router. Are you sure that your router has DHCP enabled function?
Can you also put your code here ?
Thank you:)
@nehagirme,
Users have had a lot of issues with the W5100 shield for a variety of reasons.
@rsiegel’s list is a good place to start tracking this down. Server error
I also had troubles with the w5100 but all sorted when I realised that my code was using pin 10 on the arduino which is required for the W5100.
hello, I have restarted the router and checked the DHCP function - enabled.
here goes my code:
Cayenne Ethernet Example
This sketch connects to the Cayenne server using an Arduino Ethernet Shield W5100
Steps:
#include <CayenneEthernet.h>
char token[] = "*********";
  Cayenne.begin(token);
I am still getting the DHCP failed!
Your sketch looks good, just the basic sketch that should fine. Did you go through @kreggly’s link and verify if you are experiencing anything in the post?
