Arduino MKR1000
Hello, has anyone used Arduinos MKR1000 and a DHT22 to send data to the Cayenne dashboard?
try this:
http://community.mydevices.com/t/dht11-dht22-temperature-and-humidity-sensor/6625
Ok, thanks
Sent from Yahoo Mail for iPhone
Hello, do I need to do anything else with this setup? The MKR1000 seems to disconnect after a few hours or a day and I have two Arduinos showing up in the mobile dashboard one just has an auth code and the other has all the MQTT info.
Thanks.
no, you don’t require anything else. add #define CAYENNE_DEBUG and check the serial monitor for the cause of disconnect.
this is the previous version and now you have to shift to new cayenne MQTT.
