Arduino MQTT lots of bugs
#21
#include <dht.h>
dht DHT;
char username[] = "";
char password[] = "";
char clientID[] = "";
float gas_value;
  pinMode(24, OUTPUT);
  pinMode(28, OUTPUT);
//Temperatuur DHT11 Channel 0 & Pin 6
CAYENNE_OUT(0)
  int chk = DHT.read11(6);
  Cayenne.celsiusWrite(0, DHT.temperature);
//Koolstofmonoxide Channel 1 & Pin A0
CAYENNE_OUT(1)
  gas_value=analogRead(A0);
  Cayenne.virtualWrite(1, gas_value, "co", "ppm");
//Wastafel Lamp Channel 2 Pin 24
CAYENNE_IN(2)
  if (getValue.asInt() == 0) {
    digitalWrite(24, HIGH);
  else {
    digitalWrite(24, LOW);
//Vochtigheid Channel 3 Pin 6
CAYENNE_OUT(3)
   Cayenne.virtualWrite(3, DHT.humidity, "rel_hum", "p");
//Ledstrip Channel 4 Pin 28
CAYENNE_IN(4)
    digitalWrite(28, HIGH);
  else {
    digitalWrite(28, LOW);
//Led Strip Rood
CAYENNE_IN(5)
  analogWrite(2, currentValue);
//Led Strip Groen
CAYENNE_IN(6)
  analogWrite(3, currentValue);
//Led Strip Blauw
CAYENNE_IN(7)
  analogWrite(4, currentValue);
//Lamp Kamer Channel 8 Pin ?
CAYENNE_IN(8)
//  if (getValue.asInt() == 0) {
//    digitalWrite(?, HIGH);
//  else {
//    digitalWrite(?, LOW);
//Rolluik Open Channel 9 Pin ?
CAYENNE_IN(9)
//  else {
//Rolluik Dicht Channel 10 Pin ?
CAYENNE_IN(10)
//  else {
Led strip colors sliders works on pc but takes long. doesn’t work on android at all but thats an common bug
#22
code look fine. what are problem you are facing?
#23
unless the humitidy the only problem is the speed. Before my update to MQTT everything was perfect. When i changed colors of my led strip it changed immediately, now it takes 8 seconds.
And my internet connection is fine
#24
i am not sure why there is a delay. there is a max of 2 sec delay at my end.
#25
i checked it out.
he says DHT sensor library by Adafruit version 1.2.3 is being used but when i use that version or any other version it gives errors about his code.
for example:
DHT dht(DHTPIN, DHTTYPE);
exit status 1
‘DHT’ does not name a type
#26
according to this: Sending MQTT messages within rate limits
Cayenne only uses intervals about 15 seconds.
But that should be with actuators so i don’t think that is it
#27
download and install https://github.com/adafruit/DHT-sensor-library.
next in examples open DHTtester.ino and run.
#28
btw, according to my delay issue. i see here that you fixed it for somebody else :stuck_out_tongue:
did it work for him? i think thats the same issue as me.
#29
that is a different case.
#30
is it? his case is delay on a button>relay. so is mine.
But ok, back to DHT11,
Test works
DHTxx test!
Humidity: 46.00 % Temperature: 27.00 *C 80.60 *F Heat index: 27.18 *C 80.93 *F
i will try to fix it according to this script. i will be back soon.
#31
he wants a return response from the board once the button is pressed.
#32
ok, i changed my code.
my iot script now displays the humitidy in serial but not to the dashboard:
float h, t;
  dht.begin();
      delay(2000);
      float h = dht.readHumidity();
      if (isnan(h) || isnan(t)) {
        Serial.println("Failed to read from DHT sensor!");
        return;
      Serial.print("Humidity: ");
      Serial.print(h);
      Serial.print(" %\t");
      Serial.print(t);
    //DHT11 Channel 0-3 & Pin 6
    CAYENNE_OUT_DEFAULT()
      Cayenne.celsiusWrite(0, t);
      Cayenne.virtualWrite(3, h, "rel_hum", "p");
what is wrong with my code what makes it sent “0”
#33
float h, t;
 unsigned long lastMillis = 0;
  dht.begin();
      delay(2000);
        return;
      Serial.print(h);
      Serial.print(t);
    lastMillis = millis();
      Cayenne.virtualWrite(0, t, "temp", "c")
#34
should i remove my whole function or only the virtualwrite?
#35
you can use both.
#36
nevermind it works
#37
thanks for your fast support.
this was something that never worked for me until now!
