Arduino - Neopixel control via cayenne
I am looking for an example of code that I can use manage a neo pixel strip which can be activated via wifi/cayenne … The following code manages neopixel via a “uno” - I am looking to have the ability to trigger this code via the cayene
… thanks
#include "FastLED.h"
// How many leds in your strip?
#define NUM_LEDS 64
#define DATA_PIN 7
#define CLOCK_PIN 13
// Define the array of leds
CRGB leds[NUM_LEDS];
	Serial.begin(57600);
	Serial.println("resetting");
	LEDS.addLeds<WS2812,DATA_PIN,RGB>(leds,NUM_LEDS);
	LEDS.setBrightness(84);
void fadeall() { for(int i = 0; i < NUM_LEDS; i++) { leds[i].nscale8(250); } }
	static uint8_t hue = 0;
	Serial.print("x");
	// First slide the led in one direction
		// Set the i'th led to red
		leds[i] = CHSV(hue++, 255, 255);
		// Show the leds
		FastLED.show();
		// now that we've shown the leds, reset the i'th led to black
		// leds[i] = CRGB::Black;
		fadeall();
		// Wait a little bit before we loop around and do it again
		delay(10);
	Serial.print("x");
	// Now go in the other direction.
	for(int i = (NUM_LEDS)-1; i >= 0; i--) {
		// Show the leds
		FastLED.show();
		fadeall();
		delay(10);
@cewmjtm,
Do you have a wifi or ethernet shield for your Uno or do you have an “Uno” with an integrated networking shield?
You can also connect through your USB connection using CayenneSerial.h as shown here. Arduino USB help
wifi 101 board … I have made connection with Cayenne - no problem …
Here is a copy of my current code:
Cayenne WiFi Shield 101 Example
This sketch connects to the Cayenne server using an Arduino WiFi Shield 101
Steps:
1. Install the WiFi101 library (https://github.com/arduino-libraries/WiFi101) from the Arduino Library Manager if you have not done so already.
2. Set the token variable to match the Arduino token from the Dashboard.
3. Set the network name and password.
4. Compile and upload this sketch.
#include <CayenneWiFi101.h>
char token[] = "gmbf0vxpaq";
char ssid[] = "xxxxxxxxxxxx";
char password[] = "zzzzzzzzzzzzz";
Try this :slight_smile:
#include CayenneWiFi101.h;
#define NUM_LEDS 64
#define DATA_PIN 7
void fadeall()
//Create a pushbutton and connect to virtual channel 1
//Every time it is toggled, this function will be called
VIRTUAL_OUT(1)
	Serial.print("x");
		// Show the leds
		FastLED.show();
		fadeall();
		delay(10);
	Serial.print("x");
		// Show the leds
		FastLED.show();
		fadeall();
		delay(10);
