Arduino Syntax for Virtuel Pins
Hey
I need a 0-10Volt signal on my dashboard, via virtual pin V0. (it is connected to A0).
I’m having trouble writing the correct syntax in the arduino ide.
This is what I gor so far:
#include <CayenneEthernet.h>
#define virtuel_co2 V0 //set output to Virtuel Pin V0
char token = “zdq8qohh2j”;
int co2in = analogRead(A0); // declare input
float virtuel_co2 = co2in * (2000.0 / 1023.0); //Calculation
Cayenne.begin(token);
You can see the correct syntax here: Cayenne Docs
