Arduino UNO + 8266 + MQTT
Hi there,
I successfully connected my UNO to 8266 and Cayenne through the new MQTT library, using both software and hardware serial.
Everything works, BUT data packets are sent pretty irregularly every 10/15 seconds: is this normal or should I think to a hardware issue?
The same sketch with my Node MCU8266 and the proper library works like a charm… data refreshed each 1 sec
My sketch:
#include <DHT.h>
#define DHT22_PIN 7
#define DHTTYPE DHT22
#include <CapacitiveSensor.h>
#define D2  5  // I2C Bus SDA (data)
#define D3  0
#define D4  4  // Same as "LED_BUILTIN", but inverted logic
#define IN D2
#define OUT D4
#include <SoftwareSerial.h>
SoftwareSerial EspSerial(2, 3); // RX, TX
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "";
char password[] = "";
char clientID[] = "";
ESP8266 wifi(&EspSerial);
float humidity, temp_c;
CapacitiveSensor cs_4_2 = CapacitiveSensor(IN, OUT);
    pinMode(IN, INPUT);
  pinMode(OUT, OUTPUT);
  // Set ESP8266 baud rate
Hi @suppaman78,
The same sketch on the nodemcu was also connected to Cayenne?
Yes, with different library
Passed tons of hours trying to make this work fluently, no success. In the end, I just decided to abandon the arduino/mega way, and switched my setup to MCU.
Thanks anyway
