[Arduino Uno + ESP8266 13] Can turn on an LED, but not able to turn off / receive data
I am using my Arduino Uno and the [awful] duinotech 8266 wifi shield ESP 13. Awful in that it has taken a good year or so to wrap my head around what the hell it is doing. Flashing firmware, AT commands, with it’s minimal documentation. I eventually had success using this guide. Note that the ESP 13 is a board / shield itself.
I have been able to connect to Cayenne, and add my device to the dashboard using MQTT. There is a bit of dropping in and out with the connection. I added an Led, added the bit of code needed, and then added the button widget to my dashboard.
When I click the button, the Led on my board lights up as it should. But, then the button icon on the dashboard does not reflect that the state of the Led has changed, and, on the dashboard, continues to show the loading circle. Clicking the button again while it is in this state does not turn off the Led.
Refreshing the page usually causes the board to lose connectivity, or for the button on the dashboard to be in the off state while the physical Led is on.
I suspect that no data is being received from my Arduino. And that Cayenne is waiting to receive a response state to then update the state of the dashboard.
This is supported by when even using the millis example, given within the example code, no widget is “automatically added to the dashboard” to show up time. And when I manually add a counter to receive the uptime over a predefined virtual channel, the counter does not update.
Can anyone help me with this problem?
Steps:
#include "SoftwareSerial.h"
char ssid[] = "curseduinotech";
char wifiPassword[] = "throwitinthebin";
char username[] = "MQTTXXXXXXXXXXXXXXXXXXXX";
char password[] = "MQTTXXXXXXXXXXXXX";
char clientID[] = "MQTTXXXXXXXXXXX";
#define ledpin 13
SoftwareSerial Serial1(2, 3); // RX, TX
#define EspSerial Serial1
ESP8266 wifi(&EspSerial);
	Serial.begin(115200);
	delay(10);
	// Set ESP8266 baud rate
	EspSerial.begin(9600);
	delay(10);
  pinMode(ledpin, OUTPUT);
CAYENNE_IN(1)
  digitalWrite(ledpin, getValue.asInt());
CAYENNE_OUT(0)
If you uncomment #define CAYENNE_DEBUG do you see any errors in your serial console?
Hi Adam, thanks for your time.
No errors here.
[55952] Connected to WiFi
[55952] Connecting to mqtt.mydevices.com:1883
[58579] Connected
[59942] Publish: topic 4, channel 65534, value Arduino Uno, subkey , key
[64970] Publish: topic 6, channel 65534, value ATmega328P, subkey , key
[69999] Publish: topic 7, channel 65534, value 16000000, subkey , key
[75028] Publish: topic 5, channel 65534, value 1.2.0, subkey , key
[80057] Publish: topic 8, channel 65534, value ESP8266Shield, subkey , key
[80118] Publish: topic 1, channel 0, value 80118, subkey , key
[90107] Connection ok
[95136] Publish: topic 1, channel 0, value 95136, subkey , key
[100118] Connection ok
[110148] Publish: topic 1, channel 0, value 110148, subkey , key
[111620] Connection ok
[121630] Connection ok
[125154] Publish: topic 1, channel 0, value 125154, subkey , key
[131642] Connection ok
[140165] Publish: topic 1, channel 0, value 140165, subkey , key
[141655] Connection ok
[151685] Connection ok
[155179] Publish: topic 1, channel 0, value 155179, subkey , key
[161686] Connection ok
On clicking Led button on dashboard. Led lights up within 2 seconds.
[236318] Connection ok
[245026] Message received: topic 2, channel 1
[245027] In: value 1, channel 1
[245028] publishState: topic 1 channel 1
[245031] Publish: topic 1, channel 1, value 1, subkey , key
[250065] Send response: y3tI0tIJo6qKwtI
[255093] Publish: topic 1, channel 0, value 255093, subkey , key
[260121] Connection ok
Dashboard button not changing it’s state, but still in a pending state
2018-09-03_12h36_31
@shramiksalgaonkar any ideas? Looks ok to me.
try connecting the shield manually to Rx and Tx of arduino and use Serial for communication between shield and Uno. Next comment out all serial print command and dont use Serial for debugging.
Fantastic!
I can now turn off my LED! And when I check the live data feed I am getting the milliS uptime.
You may hear from me again, but thank you to both of you.
