Hi people,
Im Trying to connect cayenne With Arduino Uno with ESP8266 wifi Connection.
First of all i tested if ESP8266 connects wifi with arduino to wifi; if i connnect RX to RX and TX to TX At commands works and connects to wifi
Than i Created New Device - Selected Arduino uno As board And Selected As board Connection as Arduino ESP8266 Wifi. Uploaded the Sketch and got error ‘Serial1’ was not declared in this scope
i researched the forum and know that it happens because arduino uno does not use Serial 1-2 etc. Than used instead of #define EspSerial Serial1 - #define EspSerial Serial;
The code did not give me error but this time im getting following error:
AT
[1529] ESP is not responding
Than i tried to add softwareserial library of arduino and added code
SoftwareSerial mySerial(0, 1); // RX, TX
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x5b
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x35
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x35
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x5d
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x61
first, remove esp8266 TX and RX pin from the Arduino. Install the ESP8266SerialLibrary.zip library via the Arduino IDE (Sketch->Include Library->Add .ZIP Library) from the Cayenne extras/libraries
folder (e.g. My Documents\Arduino\libraries\CayenneMQTT\extras\libraries). on your cayenne dashboard add a new device and get your MQTT credential. add them to below code and your wifi credentials. upload the code to your Arduino(make sure you don’t have any pins connected to RX and TX). once uploaded disconnect Arduino from your pc. connect esp8266 RX to TX of the Arduino through a voltage divider and TX of esp8266 to RX of arduino. Reconnect your arduino to pc. Open serial monitor with baud rate set to 115200. you will see something like this:
AT
ATE0
AT+CIPMUX=1
AT+CWMODE?
AT+CWJAP="Wifi","Pass"
[8095] Connected to WiFi
[8095] Connecting to mqtt.mydevices.com:1883
AT+CIPSTART=1,"TCP","mqtt.mydevices.com",1883
AT+CIPSEND=1,40
Code:
Steps:
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "";
char password[] = "";
char clientID[] = "";
ESP8266 wifi(&EspSerial);
//Serial.begin(9600);
delay(10);
// Set ESP8266 baud rate
EspSerial.begin(115200);
delay(10);
CAYENNE_OUT_DEFAULT()
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
It will “work” without the voltage divider but the ESP is 3.3v logic and Arduino is 5v logic. I have an ESP that I use specifically for testing and have never had a problem with it, but it could shorten the life of the device. Long story short, if you are just testing something you should be fine but if you are making a project definitely do it the right way.
if you are using Nodemcu, then you dont need ardiuno and esp8266. Because Nodemcu is a development board which has esp866 inbuilt and you can connect it directly to cayenne Adding a New Device using MQTT
Thanks I already did. When I open serial monitor I recieve a message statint ESP not responging. Which could be the reason for this? Do I have to buy another one?
you have powered your esp8266 from uno 3.3v and used a voltage divider ?
use this code
Steps:
2. Connect the ESP8266 as a shield to your Arduino. This example uses the Serial hardware serial pins available on the UNO.
char ssid[] = "";
delay(10);
delay(10);
thank you I will try and let you know. I already ordered a Mega and another ESP01 that is supposed to arrive today to have it in another aquarium. How is the connection with the mega?
