Arduino Yun problem compiling sketch
Hi, I have a problem with a simple code for Arduino Yun. When trying to compile the follwing example I get an error message and the compliation stops.
// This example shows how to connect to Cayenne using an Arduino Yun and send/receive sample data.
//#define CAYENNE_DEBUG
#include <CayenneMQTTYun.h>
char username[] = "";
char password[] = "";
char clientID[] = "";
unsigned long lastMillis = 0;
    lastMillis = millis();
    //Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
and here is what I get:
Arduino: 1.8.5 (Windows 7), Board: "Arduino Yún"
In file included from C:\Users\Sloneq\Documents\Arduino\YUN_CayenneMQTT_SendData\YUN_CayenneMQTT_SendData.ino:6:0:
C:\Users\Sloneq\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTYun.h:21:0: warning: "INFO_CONNECTION" redefined
 #define INFO_CONNECTION "Yun"
In file included from C:\Users\Sloneq\Documents\Arduino\YUN_CayenneMQTT_SendData\YUN_CayenneMQTT_SendData.ino:1:0:
C:\Users\Sloneq\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTSerial.h:21:0: note: this is the location of the previous definition
 #define INFO_CONNECTION "Serial"
In file included from C:\Users\Sloneq\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTSerialClient.h:28:0,
                 from C:\Users\Sloneq\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTSerial.h:25,
C:\Users\Sloneq\Documents\Arduino\libraries\CayenneMQTT\src/CayenneArduinoMQTTClient.h: In member function 'void CayenneArduinoMQTTClient::connect()':
C:\Users\Sloneq\Documents\Arduino\libraries\CayenneMQTT\src/CayenneArduinoMQTTClient.h:58:63: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
In file included from C:\Users\Sloneq\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTYun.h:25:0,
C:\Users\Sloneq\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTYunClient.h: At global scope:
C:\Users\Sloneq\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTYunClient.h:43:22: error: conflicting declaration 'CayenneMQTTYunClient Cayenne'
 CayenneMQTTYunClient Cayenne;
In file included from C:\Users\Sloneq\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTSerial.h:25:0,
C:\Users\Sloneq\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTSerialClient.h:167:25: note: previous declaration as 'CayenneMQTTSerialClient Cayenne'
 CayenneMQTTSerialClient Cayenne;
exit status 1
Fehler beim Kompilieren für das Board Arduino Yún.
Dieser Bericht wäre detaillierter, wenn die Option
"Ausführliche Ausgabe während der Kompilierung"
in Datei -> Voreinstellungen aktiviert wäre.
remove this line.
@shramik_salgaonkar It works! Thank you!
