Arduino Yun + Triggers = don't work
  • Device & model you are using Arduino Yun
  • What dashboard are you using? Web, Android
Hi
have setup little project, servo and analog sensor work, when setting up triggers, they seem not to work.
Recreated the 2 triggers, no luck.
Manually triggering servo works.
What did I wrong?
Unfortunately there are currently some issues with triggers. They are being worked on now and hopefully should be fixed very soon!
