ArduinoUno+W5100 communications problem
Hello to all,
I’m trying to let the Cayenne Libraries working.
I connected the W5100 Ethernet Shield Module to my modem.
I installed the Libraries (they are visible in the Arduino IDE), but when I upload the sketch “Arduino Uno Ethernet Shield W5 100”, this is the output:
In file included from C:\Users\alber\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTEthernetClient.h:21:0,
             from C:\Users\alber\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTEthernet.h:25,
             from C:\Users\alber\AppData\Local\Temp\arduino_modified_sketch_697077\EthernetShieldW5100.ino:14:
C:\Users\alber\Documents\Arduino\libraries\CayenneMQTT\src/CayenneArduinoMQTTClient.h: In member function ‘void CayenneArduinoMQTTClient::connect()’:
C:\Users\alber\Documents\Arduino\libraries\CayenneMQTT\src/CayenneArduinoMQTTClient.h:58:63: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
Where am I wrong?
Can you share the code you are using. Make sure you select the correct board and poft.
I’m able to communicate with the arduino alone, so I don’t think the connections are errated.
This is the code, I’ve inserted the right strings instead of the “xxx”.
Steps:
1. Set the Cayenne authentication info to match the authentication info from the Dashboard.
2. Compile and upload the sketch.
3. A temporary widget will be automatically generated in the Cayenne Dashboard. To make the widget permanent click the plus sign on the widget.
#define CAYENNE_DEBUG       // Uncomment to show debug messages
char username[] = "xxx";
char password[] = "xxx";
char clientID[] = "xxx";
CAYENNE_OUT_DEFAULT()
  //Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
[RESOLVED] I don’t know why but now it’s working. There is still the warning.
