Atas scientific stamps
will you be adding any support for these stamps ph orp salinity flow dissolved oxygen i would like support on using these devices on i2c thanks derek
Thank you in advance for taking the time to let us know about your Ideas. We truly value your input and discuss each Suggestion as a team. It would be most helpful if you could include a use case for your Idea (how it will solve a problem, or add to the usefulness of Cayenne as a proto-typing solution). Thanks!
Hi @neongt,
You should be able to add those sensors using the Cayenne - Arduino integration. I saw on their website they had some sample code for an Arduino Mega. Do you have an Arduino?
http://community.mydevices.com/t/about-the-arduino-beta-category/810?source_topic_id=1086
no i have the usb ver for raspberry pi
so would like to run them off raspberry pi thanks
