Barometric pressure Widget needs - InHG and Millibars as units
Could you please add two additional units of measure under the “Barometric Pressure” widget? New units of measure are
1.Inches of Mercury (InHg)
2.Millibars (mb)
Thank you.
Rick
Thank you in advance for taking the time to let us know about your Ideas. We truly value your input and discuss each Suggestion as a team. It would be most helpful if you could include a use case for your Idea (how it will solve a problem, or add to the usefulness of Cayenne as a proto-typing solution). Thanks!
I’d also like “millibars (mbar) / hectopascals (hPa)” for the BMP180.
Pa is a big value and im more use to hearing weather forecasts in mbar.
Thanks,
BAZ
@rjp663 @baz Agreed. Roadmapped!
