Battery Powered ESP8266 Temperature/Humidity Monitor with DHT11
#42
@pearl3 here are some projects that were made with NodeMCU, feel free to peruse and ask them questions
#43
I’m already in contact with Rich (Garage Door Opener) on Facebook. He told me about cayenne.
But we two also had no luck to get HTU21d running.
#44
I don’t have a nodeMCU to test with but one thing I can see is that you have the temp function commented out but still waiting for it to run in your if statements. Also, make sure you have a widget on your dashboard for V0 and V1 otherwise it will never execute those functions. Try the code below:
//#define CAYENNE_DEBUG
// #define DHTTYPE DHT11
// #define DHTPIN  14
#include "CayenneDefines.h"
// #include <DHT.h>
#include <SparkFunHTU21D.h>
char token[] = "";
char ssid[] = "";
char password[] = "";
//Variables for DHT11 values
//float h, t, hif;
float h, t;
bool Humidity = false;
bool Temperature = false;
//bool HeatIndex = false;
//DHT dht(DHTPIN, DHTTYPE);
HTU21D myHumidity;
  Serial.print("Setup");
  Humidity = false;
  //HeatIndex = false;
  //Run Cayenne Functions
  //Check if we got all values we wanted and sleep for 10 minutes if we did
  // if (Humidity && Temperature && HeatIndex){
    if (Humidity && Temperature){
    Serial.println("Got all values - sleeping");
    delay(100);
    ESP.deepSleep(60000000, WAKE_RF_DEFAULT);
    delay(100);
CAYENNE_OUT(V0){
  Serial.println("Entered Humidity");
  //Check if read failed and try until success
  do {
    //Read humidity (percent)
    // h = dht.readHumidity();
    h = myHumidity.readHumidity();
    delay(1000);
  } while  (isnan(h));
  Serial.print("Humidity: ");
  Serial.println(h);
  //Set Humidity to true so we know when to sleep
  Humidity = true;
  //Write to Cayenne Dashboard
  Cayenne.virtualWrite(V0, h);
CAYENNE_OUT(V1){
  Serial.println("Entered Temperature");
  do {
    //Read temperature as Fahrenheit
    // t = dht.readTemperature(true);
    t = myHumidity.readTemperature();
    delay(1000);
  } while  (isnan(t));
  Serial.println(t);
  //Set Temperature to true so we know when to sleep
  Temperature = true;
  Cayenne.virtualWrite(V1, t);
/*CAYENNE_OUT(V2){
  Serial.println("Entered Heat Index");
  do {
    //Calculate Heat Index as Fahrenheit
    hif = dht.computeHeatIndex(t, h);
  } while  (isnan(t) || isnan(h));
  Serial.print("Heat Index: ");
  Serial.println(hif);
  //Set HeatIndex to true so we know when to sleep
  HeatIndex = true;
  Cayenne.virtualWrite(V2, hif);
#45
Another question for you, were you able to read the HTU21d and print to serial with a very basic sketch without Cayenne?
#46
Indeed i made the /* at the wrong line. But unfortunately this was not the solution :frowning:
#47
Yes, i used his sensor before for an standalone temp/hum projet with lcd display.
#48
Try this for your loop:
  delay(100);
    delay(100);
    delay(100);
#49
Also, monitor your voltage. This can easily happen with the ESPs if you are running on a battery that can’t provide the transmit current of 80+ mA.
#50
Thanks but no better results:
bBʦ5bäöÎʦýÿSetup[261] Connecting to networxSAVE2
[2264] Connected to WiFi
[2264] My IP: 192.168.200.37
[5065] Connecting to arduino.mydevices.com:8442
[5438] Ready (ping: 100ms).
Entered Temperature
Exception (28):
epc1=0x40203f45 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
ctx: cont
sp: 3ffef7f0 end: 3ffefb00 offset: 01a0
>>>stack>>>
3ffef990:  3ffe8504 3ffefa44 3ffeea10 40203f41
3ffef9a0:  00007276 3ffeea10 3ffee7cc 4020404b
3ffef9b0:  3fff0bb4 3ffeea10 00000001 40202a16
3ffef9c0:  3ffefa30 3ffefa44 00000001 40202cf0
3ffef9d0:  3ffefa40 3fff0bb4 3fff0a84 40203d52
3ffef9e0:  3ffefa01 3ffee808 00000031 40203d8e
3ffef9f0:  3ffee700 3ffee808 3ffeeae0 3ffefa43
3ffefa00:  3ffee7d4 00000004 40204bc8 3ffeeae0
3ffefa10:  00000005 3ffefa40 3ffee7d4 3ffefa40
3ffefa20:  00000004 00000001 3ffee7d4 40202f66
3ffefa30:  00000000 3ffee7f4 3ffee7d4 40202dc8
3ffefa40:  31007276 3f003000 3ffeeacc 00000030
3ffefa50:  04000314 00002000 3ffeeae0 3ffee7f4
3ffefa60:  00000004 3ffefa40 40204bc8 3ffeeae0
3ffefa70:  3ffe84a0 000020fa 3ffee7d4 00000001
3ffefa80:  00000000 3ffee7f4 3ffee7d4 40203155
3ffefa90:  4010599c 0032add5 3ffee8b4 00000000
3ffefaa0:  3ffee1f0 3ffee8b4 3ffeeae0 3ffee8b4
3ffefab0:  3ffee7f4 3ffeeacc 40204bc8 3ffeeae0
3ffefac0:  4020151e 00000064 00000064 3ffeeacc
3ffefad0:  3fffdad0 00000000 3ffeeac4 40203193
3ffefae0:  3fffdad0 00000000 3ffeeac4 40204c14
3ffefaf0:  feefeffe feefeffe 3ffeeae0 40100718
<<<stack<<<
#51
As you can see, sensor is working with SparkFun HTU21s sample sketch in the same setup:
0‚~?–4“Ò¶£ÿOCAEüûHTU21D Example!
Time:326 Temperature:22.5C Humidity:44.3%
Time:1398 Temperature:22.5C Humidity:44.3%
Time:2471 Temperature:22.5C Humidity:44.3%
Time:3543 Temperature:22.5C Humidity:44.3%
Time:4616 Temperature:22.5C Humidity:44.3%
Time:5688 Temperature:22.5C Humidity:44.3%
#52
I’d like to know how much current the ESP devices draw, too.
My Fluke ammeter only has 3.5 digit resolution,
and only down to 1/100th an amp, so it only shows 00.01 A.
Not accurate enough.
I need a milliammeter.
I don’t have one.
I’d surely like to know.
I’m imagining the ESP12-e draws
something like 35 mA (milliamps),
-just a WAG.
#53
Do you Google Bro? :slight_smile:
Spec sheet says 80 mA, I’ve measured 86 or so for my modules.
On the raw modules, you need to put at least a 220uF capacitor across the 3V3 to keep it from resetting when connecting to the cloud server. Perhaps if I use multi-core wire for connection, this wouldn’t be as necessary… but a capacitor works.
#54
I’ve been becoming fond of using the 78SR3.3 voltage regulators.
It works well for me,
while using a 47 muff cap on either side of the regulator.
That 220 muff cap takes up a lot of real estate,
but changing the 47 muff cap
to a 1 muff cap wouldn’t gain me much space,
and 47 muffs is (much) more than adequate.
The 78SR3.3 is a VERY efficient switcher,
and also allows for a VCC of up to +36,
and eliminating the need of a large +V filter capacitor-
it’s a switching regulator, as such (by definition) filters out AC line ripple
and other spurious electrical noise.
It would be interesting to see
how long 2 standard 9V batteries (in series) would last
in this configuration.
The minimum V(in) voltage on the 78SR3.3 is 7.5V.
@kreggly - I’ve vaguely heard of Google.
I can’t quite pin where I’ve heard that term before…
:stuck_out_tongue_winking_eye:
http://www.kloppenborg.net/images/blog/esp8266/esp8266-esp12e-specs.pdf
#55
I like this project I am going to implement similar project for green house control system :slight_smile:
#56
Any other hints for my problem? I’m pretty sure this is not a voltage problem as i had othr projects with blynk i.e. before…
#57
Install this, https://github.com/me-no-dev/EspExceptionDecoder, and see what it says.
Also, post your whole sketch and one of us can try it and see if we can repeat your error.
#58
Or is there anybody with nodeMCU an HTU who can copy my setup?
#59
Maybe, if you post your full sketch :wink:
#60
You will find it up there 38/58 :wink:
// #include <DHT.h>
char token[] = "";
char ssid[] = "";
//float h, t, hif;
float h, t;
HTU21D myHumidity;
  Humidity = false;
  delay(100);
    delay(100);
    delay(100);
CAYENNE_OUT(V0){
  do {
    delay(1000);
  } while  (isnan(h));
  Serial.println(h);
  Humidity = true;
CAYENNE_OUT(V1){
  do {
    delay(1000);
  } while  (isnan(t));
  Serial.println(t);
  Temperature = true;
/*CAYENNE_OUT(V2){
  do {
  HeatIndex = true;
#61
Take a seat @kreggly!
Anyway…let’s try doing some serial prints to see where you’re getting caught up. Try this and post the output.
  Serial.print("Cayenne setup");
  Humidity = false;
  Serial.print("Begin loop");
  Serial.print("End Cayenne.run");
  delay(100);
    delay(100);
    delay(100);
  Serial.print("End loop");
