Bcm2835 High-Precision AD/DA Board
Hi, i want to connect extension board bcm2835 High-Precision AD/DA Board to my Raspberry pi 3, is there any possibility to add this, because i didn’t found it under given possibilities. Did i overlook it?
Thank you!
Sure, you need to use MQTT and a driver for that part. Then setup using Bring Your Own Device on the dashboard.
I recommend Python as there is lots of examples for the Pi already .
https://pypi.python.org/pypi/PyBCM2835/0.1.0
