No need to apologize, that’s why I post it here
Can you try this script and paste back the output?
import smbus
import time
import os
import sys
time.sleep(30) #Sleep to allow wireless to connect before starting MQTT
username = "1234567890"
password = "abcdefgghi"
clientid = "12345-abcd"
mqttc = mqtt.Client(client_id=clientid)
mqttc.username_pw_set(username, password=password)
mqttc.loop_start()
topic_si7021_temp = "v1/" + username + "/things/" + clientid + "/data/3"
topic_si7021_humidity = "v1/" + username + "/things/" + clientid + "/data/4"
while True:
try:
# Get I2C bus
bus = smbus.SMBus(1)
bus.write_byte(0x40, 0xF5)
time.sleep(0.3)
# SI7021 address, 0x40 Read 2 bytes, Humidity
data0 = bus.read_byte(0x40)
data1 = bus.read_byte(0x40)
# Convert the data
humidity = ((data0 * 256 + data1) * 125 / 65536.0) - 6
time.sleep(0.3)
bus.write_byte(0x40, 0xF3)
time.sleep(0.3)
# SI7021 address, 0x40 Read data 2 bytes, Temperature
# Convert the data and output it
celsTemp = ((data0 * 256 + data1) * 175.72 / 65536.0) - 46.85
fahrTemp = celsTemp * 1.8 + 32
if fahrTemp is not None:
print("temp: " + str(fahrTemp))
fahrTemp = "temp,f=" + str(fahrTemp)
mqttc.publish(topic_si7021_temp, payload=fahrTemp, retain=True)
else:
print("temp is None")
if humidity is not None:
print("humidity: " + str(humidity))
humidity = "rel_hum,p=" + str(humidity)
mqttc.publish(topic_si7021_humidity, payload=humidity, retain=True)
else:
print("humidity is None")
time.sleep(5)
mqttc.disconnect()
sys.exit()
