BME280 - pressure, temperature and humidity sensor
Codes for different boards and shields.
All codes only work with MQTT.
ESP8266.txt (1.8 KB)
Arduino_Industrial_101.txt (1.0 KB)
EthernetShieldW5100.txt (2.1 KB)
EthernetShieldW5200.txt (2.3 KB)
EthernetShieldW5500.txt (2.3 KB)
MKR1000.txt (2.4 KB)
ManualConnection.txt (3.0 KB)
WiFi101Shield.txt (2.4 KB)
WiFiShield.txt (2.2 KB)
Sample from the Cayenne Dashboard.
Hi
Is there a BME280 download for the ESP32 board?
No, but I’ll write it for you in 24h.
Spectacular! Thanks very much. I’m in no rush since my BME280 hasn’t arrived yet
Try this, but I do not know if it works because I do not have ESP32.
This example shows how to connect to Cayenne using an ESP32 and send/receive sample data.
Steps:
1. If you have not already installed the ESP32 Board Package install it using the instructions here: https://github.com/espressif/arduino-esp32/blob/master/README.md#installation-instructions.
2. Select your ESP32 board from the Tools menu.
//#define CAYENNE_DEBUG
#include <CayenneMQTTESP32.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#define I2C_SDA 32
#define I2C_SCL 33
Adafruit_BME280 bme(I2C_SDA, I2C_SCL);
char ssid[] = "ssid";
  bme.begin(0x76);
CAYENNE_OUT_DEFAULT()
  Cayenne.celsiusWrite(1, bme.readTemperature());
  Cayenne.virtualWrite(2, bme.readPressure(), "bp", "pa");
  Cayenne.virtualWrite(3, bme.readHumidity(), "rel_hum", "p");
CAYENNE_IN_DEFAULT()
Thanks very much. My BME280 hasn’t arrived yet, but when it does, I’ll let you know how it works.
Hello works great so far for my ESP 8266. Would like to add a deep sleep mode but cannot handle to find the right place for it to get it work… Would be great if you could help me. Thanks.
here is an example Battery Powered ESP8266 Temperature/Humidity Monitor with DHT11
