BMP180 widgets, can't rename one without the other changing, also decimal place selection
IOS 9.3.1 and web
What OS? (Jessie, Wheezy)
Wheezy
What Model Pi?
Pi 2
I added a BMP180 device to monitor temp and b-pressure. After adding the sensor two widgets were created for me but I cannot rename one without the other. When you change the name of one, the other changes as well.
Also, it would be nice to be able to truncate/round the numbers that are displayed. In my case I just don’t need to know the temperature to two decimal places.
Bruster
+1
Yup, me too.
Ian
I don’t really see this as an issue, but it might be a better idea to create widget groups for sensors with more than one output if they have to have the same name.
Moving this to Ideas / Suggestions for allowing to change name of two widgets on same sensor (hope you don’t mind) so I can track in road map. And also decimal place.
Thanks for sharing this!
It would be nice to change also the units, or add a formula to change the values from pascal, to any measure unit (mmHg, bar, psi etc etc)
