Using sensor above i had perfectly good reading both Serial and Cayenne dasboard for pressure value.
Then it got funky, without changing anything (No lib or code change) sensor started showing around 500hpa more in pressure.
I am measuring outside pressure, and with time it changes value, so its picking up some data but they are wrong. Temperature readings are ok.
Library used is by Adafruit and module
Anyone had similar issue.
