Hi, using Arduino Uno with Cytron ESP-WiFi shield. Used Cayenne code, can upload but board does not connect to Cayenne so unable to proceed further. Appreciate your advice and assistance to resolve the problem.
Thks.
Rgds
Arul
Thks.
Rgds
Arul
Cytron_ESP.txt (3.1 KB)
Hi, Pl see txt file. I am able to compile and upload but just will not connect to Cayenne Dashboard. Ping the website and i got 100% packet lost, simply not connecting. Thks.
you need to use the hardware serial port of Uno.
Steps:
2. Connect the ESP8266 as a shield to your Arduino. This example uses the Serial hardware serial pins available on the UNO.
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "";
char password[] = "";
char clientID[] = "";
#define EspSerial Serial
ESP8266 wifi(&EspSerial);
//Serial.begin(9600);
delay(10);
// Set ESP8266 baud rate
EspSerial.begin(115200);
delay(10);
CAYENNE_OUT_DEFAULT()
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
