Bug Filed on 01-04-2016: Remove Sensor from Dashboard Crashed myDevices Service
Jessie
8GB
Pi2
I removed a BMP180 sensor from the dashboard and it hung on removing for a bit then the myDevices service crashed and the dashboard was showing my pi as offline. After a restart of myDevices and webiopi services everything appears to be back to normal and the sensor was gone from the dashboard. I made a copy of the last log file if you want to look at it.
Just add to this observation on both my Rasparian / Pi2:
Have noted that there is often a temporary or momentary ‘disconnection’ when a generic (pin header IP or OP) DI / DO sensor is being removed but not noticed any permanent issues.
More an issue is inability to add any outputs at moment (no success in last fe days)
~ Andrew
@svazir @akaranfilian Issue with removing a sensor with Jessie, let’s duplicate and get this in a sprint, thanks!
Weird, think you can post the log file?
@picaxe @ats1080s I’m gonna resolve this thread. Hopefully a momentary, random, will never happen again ever occurrence. :slightly_smiling: And some of our recent release may have fixed whatever happened too.
