Bug Filed on 02-01-2016: I had the service running then it stopped
I’m on ethernet connection
also Online and when SSH to Pi still cant ping google…
this message : ping: icmp open socket: Operation not permitted
Do you have a few mins to debug?
My skype is bennyestes11
sorry not now…
You have to use sudo ping google.com
hi all
sudo ping google.com work when offline…
Do you have time in upcoming days to do a quick debug session?
Hi
I can do it in about 1 hour if you free to talk.
Sorry, I wasn’t available. Let me know if you are in next 8ish or so hours! my skype is bennyestes11
Hello guys,
The issue seems to be the service type used before and with the new agent.
Before was using init.d and now is using systemd.
You can run these commands to fix it:
systemctl disable myDevices
rm /etc/init.d/myDevices
systemctl enable myDevices
Allthrough other errors were showing in debug this will fix the issue.
The fix will come with next agent release.
Thanks @ats1080s for the help. Your pi has this fixed since we have debugged also on this.
Teo
Looks like its good now, thanks!
hello guys
can you explain in details steps done by tdeleanu… when I run this line :
got error say no such file or directory…
Hi @greku69,
Possible that you have other issue than ats.
I will contact you on private.
Thanks for your questions!
@elentz @ats1080s @greku69 Hey guys, this issue should be resolved now. Please let us know if it comes up again, and thanks you for your patience!
