Bug Filed on 02-18-2016: Never past libraries (Fix Edit: need to expand file system)
1. What OS? (Wheezy or Jessie) Jessie (not lite)
2. What class/size SD card? (ex. class 10 16gb)16gb
3. What Model Pi? (A+, A, B+, B, Pi2)b+
On my app it never gets past installing libraries.
Did your iPhone go to sleep during the install process?
No. I’ve made it a point to keep the phone from doing that.
For me it´s never ending storry, hangs widht install libery nothing happends
Hey!
I’m sorry to hear that you guys are encountering some problems.
Are you both using Jessie?
If so, have you expanded the SD card prior to installing?
If you do not recall, you can use the command df to check that the available space is correct.
@hardisty.dan @hasse38 Let us know when you get a chance to expand the filesystem on the SD card and try again. Thanks!
Moving this to the Resolved category.
