Bug Filed on 02-25-2016: Cannot install for Python 3.4.2 : missing development headers
1. What OS? (Wheezy or Jessie)
Jessie
2. What class/size SD card? (ex. class 10 16gb)
32gb
3. What Model Pi? (A+, A, B+, B, Pi2)
Pi2 B+
4. Please describe the bug / issue. Attaching any relevant screenshots would be very helpful! Thanks in advance.
Continue to get error that python-dev cannot be found… For some reason your install keeps overwriting what is already installed and then fails. I then do apt-get -f install and it reinstalls the newer python 3.2-dev libraries.
Thu Feb 25 09:24:40 PST 2016 Installing myDevices agent
Thu Feb 25 09:24:58 PST 2016 Installing system libraries
Thu Feb 25 09:24:59 PST 2016 Installing python3-dev
(2%)
Thu Feb 25 09:25:04 PST 2016 Installing debian package: libpython3.2_3.2.3-7_armhf.deb
(4%)
Thu Feb 25 09:25:09 PST 2016 Installing debian package: libssl1.0.0_1.0.1e-2+rvt+deb7u17_armhf.deb
(6%)
Thu Feb 25 09:25:40 PST 2016 Installing debian package: libssl-dev_1.0.1e-2+rvt+deb7u17_armhf.deb
(8%)
Thu Feb 25 09:25:54 PST 2016 Installing debian package: libexpat1_2.1.0-7_armhf.deb
(10%)
Thu Feb 25 09:26:16 PST 2016 Installing debian package: libexpat1-dev_2.1.0-7_armhf.deb
(12%)
Thu Feb 25 09:26:58 PST 2016 Installing debian package: python3.2-dev_3.2.3-7_armhf.deb
Thu Feb 25 09:26:59 PST 2016 Found Python 3.4.2…
(80%)
Thu Feb 25 09:26:59 PST 2016 Copying agent libraries
(85%)
Thu Feb 25 09:27:12 PST 2016 Installing python utils
(90%)
Thu Feb 25 09:27:13 PST 2016 Installing agent
Thu Feb 25 09:27:14 PST 2016 Cannot install for Python 3.4.2 : missing development headers\n
Thu Feb 25 09:27:14 PST 2016 Finished agent code
Thu Feb 25 09:27:14 PST 2016 ERROR: myDevices cannot be installed - please check errors above
apt-get -f install output
Reading package lists… Done
Building dependency tree
Reading state information… Done
Correcting dependencies… Done
The following extra packages will be installed:
libpython3.2 python3.2-dev
The following packages will be upgraded:
2 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
2 not fully installed or removed.
Need to get 0 B/22.8 MB of archives.
After this operation, 7484 kB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database … 117623 files and directories currently installed.)
Preparing to unpack …/python3.2-dev_3.2.4-1+b1_armhf.deb …
Unpacking python3.2-dev (3.2.4-1+b1) over (3.2.3-7) …
Preparing to unpack …/libpython3.2_3.2.4-1+b1_armhf.deb …
Unpacking libpython3.2 (3.2.4-1+b1) over (3.2.3-7) …
Processing triggers for man-db (2.7.0.2-5) …
Setting up libpython3.2 (3.2.4-1+b1) …
Setting up python3.2-dev (3.2.4-1+b1) …
Processing triggers for libc-bin (2.19-18+deb8u3) …
Hi @ctaylor,
Welcome to the Cayenne Community. This is a known issue with Jessie Lite. There is a workaround here:
Let us know if you continue with issues? (We’re working to officially support Jessie Lite).
Ah, didn’t realize I was using Jessie lite - Pretty sure I had installed from the regular Jessie tree, not the lite source tree.
No worries! Let us know if you are still having issues?
Were you able to get the install to work?
In my case it was resolved with sudo apt-get install python3-pip
Got it, thanks for sharing.
