If you are only using 1.3G then you definitely have the lite version. Full version is around 3G with nothing else installed.
Thank, is it possible to upgrade to the full version without reinstalling??
Hope that thats possible.
Check this out
I kept getting this on one of my A+ piās running Jessie Liteā¦ turned out that because I had customised /tmp it wouldnāt install either due to size requirements. I had set /tmp at 50MB using tmpfs (RAMDISK) and thus it would not install (required 200MB). A+ only has 256MB total so I had to remove my ramdisk /tmpā¦ run the install and then reinstate.
I use this so that I can dump text into RAM instead of the SD card, thus increasing its life.
I guess I could also have hacked the setup.sh to use a different path too.
Hello, same issue here. i want to install on a working piaware from flight aware unit that i have already running outside, to add some sensors.
pi@piaware ~ $ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 7.2G 2.3G 4.6G 33% /
devtmpfs 214M 0 214M 0% /dev
tmpfs 44M 244K 44M 1% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 22M 0 22M 0% /run/shm
/dev/mmcblk0p1 56M 20M 37M 36% /boot
tmpfs 22M 4.0K 22M 1% /tmp
System hostname piaware (127.0.1.1)
Operating system Debian Linux 7.11
Webmin version 1.810
Time on system Fri Aug 12 15:34:56 2016
Kernel and CPU Linux 4.1.19+ on armv6l
System uptime 0 hours, 11 minutes
Running processes 78
CPU load averages 1.40 (1 min) 1.00 (5 mins) 0.52 (15 mins)
CPU usage 81% user, 19% kernel, 0% IO, 0% idle
Real memory 98.54 MB used, 434.94 MB total
Local disk space 2.62 GB used, 7.16 GB total
i did the raspi config resize thing, and rebooted, but still stuck at install.
any pointers to fix this?
thanks!
Welcome to Cayenne!
Looks like youāre running wheezy which isnāt supported any more. You will have to upgrade to Jessie to get Cayenne installed.
Hi! Have the same Setup requires at least 200Mb for install
problem on piaware image based on Raspbian GNU/Linux 8.0 (jessie) on Rasberry Pi 3:
pi@img-1e:/$ uname -a
Linux piaware 4.4.0-1-rpi2 #1 SMP Debian 4.4.6-1+rpi14 (2016-05-05) armv7l GNU/Linux
pi@img-1:/$ cat /proc/version
Linux version 4.4.0-1-rpi2 (debian-kernel@lists.debian.org) (gcc version 4.9.2 (Raspbian 4.9.2-10) ) #1 SMP Debian 4.4.6-1+rpi14 (2016-05-05)
pi@img-1:/$ lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 8.0 (jessie)
Release: 8.0
Codename: jessie
pi@img-1:/$ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
NAME="Raspbian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
pi@img-1:/$ df -h
udev 10M 0 10M 0% /dev
tmpfs 185M 4.7M 181M 3% /run
/dev/mmcblk0p2 7.2G 1.8G 5.1G 26% /
tmpfs 463M 4.0K 463M 1% /dev/shm
tmpfs 463M 0 463M 0% /sys/fs/cgroup
tmpfs 463M 19M 445M 4% /tmp
/dev/mmcblk0p1 128M 55M 73M 43% /boot
tmpfs 93M 0 93M 0% /run/user/1000
This is what I get after sudo bash rpi_XXXXXXXXXXX.sh -v
+ set -x
+ exec
(0%)
Thu May 4 15:18:49 MSK 2017 Installing myDevices agent
(-1%)
Thu May 4 15:18:52 MSK 2017 Installing myDevices agent
Any idea to fix it?
Have a look at this thread Unable to install on raspberry pi 3
Basically the problem is that you have a non-default partition layout so youāll have to modify the installer script to match what you have.
Thank you, it helped! Have changed
availableSize=df -k | head -2 | tail -1 | awk '{print $4}'
to
availableSize=df -k | head -4 | tail -1 | awk '{print $4}'
and commented out downloading and extracting myDevices-1.0.tar.gz
in rpi_XXXXXXXXXXX.sh
preventing overwrite my changes in myDevices-1.0/setup.sh
I am having similar issues.
my df-h
pi@raspberrypi:~ $ df -h
/dev/root 27G 4.6G 21G 18% /
devtmpfs 460M 0 460M 0% /dev
tmpfs 464M 0 464M 0% /dev/shm
tmpfs 464M 6.3M 458M 2% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 464M 0 464M 0% /sys/fs/cgroup
/dev/sda6 68M 22M 47M 32% /boot
/dev/sda5 30M 446K 28M 2% /media/pi/SETTINGS
Running
pi@raspberrypi:~ $ cat /etc/os-release
PRETTY_NAME=āRaspbian GNU/Linux 9 (stretch)ā
NAME=āRaspbian GNU/Linuxā
VERSION_ID=ā9ā
VERSION=ā9 (stretch)ā
ID=raspbian
ID_LIKE=debian
HOME_URL=āhttp://www.raspbian.org/ā
SUPPORT_URL=āRaspbianForums - Raspbianā
BUG_REPORT_URL=āRaspbianBugs - Raspbianā
Always stops at
./myDevices-1.0/3rd_party/suds-jurko-0.6.tar.gz
- set -x
- exec
(0%)
Wed Apr 4 18:10:39 ADT 2018 Installing myDevices agent
Any Ideas
