Bug Filed on 03-14-2016: Analog Input widget loses data
Jessie
Class 6 16GB
Pi2
I have set up an “Analog Input widget” for channel 0 of an MCP3008 A to D converter. It initially works, but if I shut down the Pi2 and restart it, the widget is there but no data. The MCP3008 appears to be operating correctly. I have to “remove” the sensor and then make a new one.
One suggestion would be to add a “scaling” factor to the widget setup. For example, if there was a voltage divider on an input attached to a battery, the display could then be scaled to reflect the battery voltage ie. “12.0” in place of “1.00”. Just a thought…
Thank You
@james_solum Are on the app or dashboard?
On the dashboard.
Jim
Hey Jim,
We’ve finally reproduced. We’ll investigate for a fix and I’ll update this post.
