Bug Filed on 03-24-2016: Multiple actions at the same time
----------Jessie
---------- 8hb
---------- B+
If 2 inputs are pressed or released (high/low) at the same time, sometimes one of two actions are missed.
Example:
Pin 18 Goes high -> Pin 23 should go high
Pin 18 Goes Low -> Pin 23 should go low
Pin 17 Goes High -> Pin 24 should go high
Pin 17 Goes Low -> Pin 24 should go low
If Pin 18 & 17 goes high at the same time, sometimes the pin 24 high action is missed
When the action is missed, do you know if the changed of the missed action (Pin 17 going to High/Low) is reflected as changed on the dashboard?
The state of the input pin DOES change on both the GPIO monitor screen and dashboard. The state of the output pin DOES NOT change on either
