Bug Filed on 04-04-2016: Cant install from app
android
Wheezy
8
pi2
it just keep saying its installing for 30 min and nothing happen
Did you expand the file system on the Pi prior to installation of Cayenne?
I would also recommend using the Jessie OS. Raspberry Pi no longer officially support Wheezy, and it’s kind of older.
i will try
thank you :slight_smile:
how do i expand the file system on the Pi prior to installation?
no need, got how to do it
do i have to install Jessie ?
Great! yep, we recommend Jessie, the full version.
Hi there,
Any update with your progress?
I had this issue yesterday on rpi b+ with class 10 16gb running jessie.
When installing directly from Android app onto a new raspbian image the setup halts at “resizing and rebooting”. I have to log in to the rasperry and resize sd card manually in raspi-config, then I can start the installation again from the app and it installs like normal.
That sounds about right. We are working on updating the Cayenne installer to automatically expand the file system when it was not previously expanded, which should get rid of this problem.
We’ve implemented a fix where Cayenne will automatically expand the file system. Moving this topic to resolved.
