Bug Filed on 04-06-2016: Trigger work flow and lableing glitch - Android
android
When reporting bugs, it’s most helpful if you can include:
  • Android device info (e.g. Nexus 6P)
    Cayenne for Android build 0.44a
    Samsung S5 Active
  • Raspberry Pi device info (e.g. Pi 2 w/ Raspbian Jessie version 02/26)
    Multiple (Zero, 2b, 3b) various versions of Jessie from February on…
Any time you can, please send us screenshots showing your issue on the device or highlighting your feedback. Screenshots are very helpful!
Trying to get to a trigger, spicificly PIR to Light on, I keep getting dumped back to the Devices page. This does NOT happen when trying to select other triggers…
From Devices I select RPi 3008
and then select triggers
and then when I select the PIR to Light on trigger
I get tossed back to the Devices page
…however when selecting other triggers there is a labeling problem-
From devices if I select RPi 3008
and then select a trigger for DVK512 is ONline
I get to a trigger page that has the proper name of DVK512 is ONline but states “If RPi 3008…”
This is the same trigger from the online desktop.
I did delete and reload .44a and still get the same responses.
Ian
These issues still happening with latest build? (.46a)
Labeling is fixed.
Still getting tosed to devices when selecting PIR to light on
Ian
Got it thanks, we’ll keep looking into this. It might be a global issue outside of Android app. Yay.
Hey @Ian,
We’ve released several updates on Android, let us know if this is not fixed. Thanks!
