Bug Filed on 04-28-2016: pca9685
Android & Web
What OS? (Jessie, Wheezy)
What Model Pi?
Rasp 2
I have the PCA9685 working in channel 7 connected to a LED, just to understand how it works. Works perfect but it seems that, after rebooting the control does not work anymore.
Now, if I go to settings, change from channel 7 to channel whatever and save and then again from channel whatever to channel 7, it works again.
Any ideas ?
Thank you and regards
Roger
Can you try using the ‘Luminosity’ widget and see if the issue reproduces? I’m assuming you used a generic 'PWM Output widget"?
I am using the Luminosity widget.
I deleted it and created an Analog Actuator it seems that works OK after a couple of reboots.
Now I deleted the Analog Actuator and created the Luminosity again and after several reboots always worked. Strange.
If this happens again I will let you know.
Yes, please let us know. Thanks for reporting! I’ll move this topic to resolved now if you don’t mind.
