Bug Filed on 04-28-2016: Temperature Trigger iOS
ios
iOS
What OS? (Jessie, Wheezy)
Jessie
What Model Pi?
Pi2
When I set a trigger for a notification with a maximum Temperature e.g.: 28 in °C value and save it, I get immediately a warning that the temperature is above the maximum defined value 28 °F.
The unit °C is not saved and is always switching back to °F
We’ll have to test this one out in-house. I wasn’t aware of this. Regardless, it should be fixed with next iOS update.
Thanks for reporting the iOS bugs, it helps :slight_smile:
We just released an iOS update. Can you let us know if this was fixed when you get a chance? Thanks!
Great! I checked it and it is fixed!
