Bug Filed on 05-09-2016: Remote access doesn't work
remote-access
IOS / WEB
What OS? (Jessie, Wheezy)
Jessie
What Model Pi?
3
I can attach my RPi3 using iOS app but when I try to remote control an error appear.
any help? I need to install additional software to enable this functionality? java, vnc, etc?
thanks!
Did you enable pop ups?
I have a same problem.
Did you already install tightvnc on your Pi?
No
I have VNC viewer.
Yes. I can see the pop up screen. but with an error.
david
Yes, I use tightvnc.
tnks!
david
Can you ping the rpi?
Then You need to install the Tightvnc server onto your rpi and use a vnc viewer on your pc/ipad to gain remote access to rpi
Try to get remote access before installing Cayenne then you get all the basics working before layering software packages
Sorry for the inconvenience this issue should be fixed now. Please let us know if you are still experiencing the issue.
Sumeet
Super , it works without problems.
Great to hear! Moving this issue to resolved.
@barrie @dreifs this should be resolved now.
I’ve installed the tightvnc and it work’s if I try to connect using LAN connection and internal IP.
If I try to connect througth mydevices app doesn’t work
for me the issue is still alive.
david
#14
Yes, if you have previously installed tightvnc, then the myDevices remote desktop will have issues. See this thread: Bug Filed on 03-28-2016: Remote access problems [Fixed: suppress existing tightvnc connection]
