Bug Filed on 06-13-2016: Add trigger from web browser
Web (Chrome, Mozilla Firefox, Internet explorer)
What OS? (Jessie, Wheezy)
Jessie 4.4
What Model Pi?
Model B+
When I like to drag some devices in add new trigger view on web browser from my PC and I like to drag some device to “If” device or “Then” device, nothing was happening. From my android device I can add trigger without any problem.
Best regards,
prontoo
Are you dragging the actual sensors? Can you drag the Pi device itself first and then once the Pi is added to the triggers statement you should be able to select sensors connected to it. Let me know if this was the issue, thanks!
Yes, I must first to drag Raspberry PI and then to select device.
Thank you,
bastes
No problem! We’re updating UI to allow to drag an actual sensor, like you were trying to do. Thanks for asking! I’ll move this to ‘Helped’ category.
