Bug Filed on 06-20-2016: GPIO Not Access
web as well as android
What OS? (Jessie, Wheezy)
jessie
What Model Pi?
model B+ 512MB Ram
Currently I set new device (Relay) in both web as well as android.
Once i press on light on GPIO is not accessing and only process round is start at icon.
GPIO as well as icon is not give response properly.
This is made for Home Automation response to GPIO is almost not there if it is there it will take too much time to turn on and off the GPIO pin.
Hi @ba_bhansali,
Are you on WiFi? Have you also doubled check you wiring? Perhaps it would help to add an LED and use the GPIO to turn it on / off…this way we know the GPIO is functioning as expected and we can narrow issue down to the relay.
