Bug Filed on 07-08-2016: Removing extensions
Hello All,
I am not able to connect the analog photoresistor to cayenne web app as per the tutorial. I followed the below diagram.
Once the circuit assembly is done, I followed the process to add it to the dashboard but the IO and the connectivity section is not highlighted.
Please help
@satyajeet
Satyajeet,
Have you added the MCP3008 ADC to Cayenne? If not, it needs to be added. The I/O and Connectivity options should be available after the MCP3008 is added.
Again, welcome,
-Ian
Thanks Ian
I was able to add the analog to digital converter IC (MCP3008).
But, it shows a couple of Extensions of the same name (MCP3008).
Please refer the below screenshot
Please let me know how to remove one of them.
Satyajeet,
This is/was a known bug, and I’m not sure if it has been resolved.
@bestes Benny, is removing extensions still a problem?
Ian
Hi @satyajeet, Hi @Ian,
Unfortunately, Ian is correct, this is a known issue that is in our backlog of fixes to get out the door. It will be fixed in a future release.
