Bug Filed on 07-25-2016: Extension MCP3208 missing 1 bit?
Web
What OS? (Jessie, Wheezy)
Jessie
What Model Pi?
rpi2b and rpi Zero
I’ve noticed that a lot of improvement have been made and I can now delete widgets from extensions. One ting that has also changed, is that the values for the Extension MCP3208 are displayed and moving correctly, but all values (float, integer, Volt,…) are exactly 1/2 of what they should be.
To be correct, I’m using a MCP3304 (a newer version of the MCP3208) that worked fine before as a MCP3208.
Anyone else seen this affect?
BTW, I could only add one channel to the extension, a second one is stuck on the extension pic
Hey @scheltovandoorn,
Thanks for posting this. Let me try and reproduce this and get back to you with my findings.
Thanks, no rush.
