Bug Filed on 08-29-2016: Cayenne crashes Rasberry Pi
I am running cayenne on my Raspberry Pi 3. After 20 to 40 minutes the Pi crashes. I know this is due to cayenne as it runs fine without cayenne. I have reinstalled cayenne but still the same problem
Do you see any errors in your error log?
tail -n 50 /var/log/myDevices.log
You can increase the 50 value to get more lines.
Sorry but I deleted cayenne before checking the log. I shall try
reinstalling directly from the Pi and the website rather than using the
iPhone app Regards Simon
Simon Woodhead Sent from my iPhone
Hi Adam I have seen the video on how to install cayenne from the web onto
the Pi, but I cannot t see the text to type into the pi. The Web browser
keeps crashing each time I try to view the text. Please could you send me
the text that I need to type into the pi terminal in order to install the
software Regards, Simon
Simon Woodhead
Hi Adam , I tried the following see picture below but recent bed an error
message on the Terminal that the connection failed to establish a link to
the web page Please advise Regards Simon
Simon Woodhead
For the command you will have to use the command that is shown on your dashboard. Unfortunately there is no other way to install Cayenne. Can you try to access the dashboard on a different computer to see if the page loads there?
This is the command that I have from your web page. See attached. I assume
the wget should be on the same line as the rest of the code with no Return
key between them… Unfortunately when. You run this code it does not work.
Perhaps the only way to install the code is through the iPhone app. Please
advise
Simon Woodhead
That’s just the example command. The file name in the command from the dashboard will be something like ws77ej1ysl.sh for the wget and sudo sh commands. That file name is unique to your dashboard and your Pi won’t show up unless you use it. If you’re comfortable PM’ing me your login details I can get the correct code for you, just make sure you change your password before and after.
Thank you I am a beginner at this
Please send the complete command text so I can copy and paste Regards Simon
Some more data 16-08-16 13:38:08 - myDevices - INFO - Save History Averages 2016-08-16 13:38:08 - myDevices - INFO - Memory usage : 82 size: 24384 2016-08-16 13:38:08 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=195.69, ru_stime=20.53, ru_maxrss=24384, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=721497, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=8064, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=96841, ru_nivcsw=33031) 2016-08-16 13:38:08 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:38:08 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:38:08 - myDevices - INFO - PacketTypes.PT_UTILIZATION 2016-08-16 13:38:37 - myDevices - INFO - ExecuteMessage: 4 2016-08-16 13:38:38 - myDevices - INFO - History CalculateAverages increment: 77 2016-08-16 13:38:38 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {}} 2016-08-16 13:38:38 - myDevices - INFO - Save History Averages 2016-08-16 13:38:38 - myDevices - INFO - Memory usage : 83 size: 24384 2016-08-16 13:38:38 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=197.95, ru_stime=20.76, ru_maxrss=24384, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=730642, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=8144, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=98032, ru_nivcsw=33371) 2016-08-16 13:38:38 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:38:38 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:38:38 - myDevices - INFO - PacketTypes.PT_UTILIZATION 2016-08-16 13:38:57 - myDevices - INFO - SendHistoryData previously SendFailed items: [] 2016-08-16 13:39:07 - myDevices - INFO - ExecuteMessage: 4 2016-08-16 13:39:08 - myDevices - INFO - History CalculateAverages increment: 78 2016-08-16 13:39:08 - myDevices - INFO - Memory usage : 84 size: 24392 2016-08-16 13:39:08 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=200.25, ru_stime=20.98, ru_maxrss=24392, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=740384, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=8216, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=99410, ru_nivcsw=33745) 2016-08-16 13:39:08 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:39:08 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:39:08 - myDevices - INFO - PacketTypes.PT_UTILIZATION 2016-08-16 13:39:37 - myDevices - INFO - ExecuteMessage: 4 2016-08-16 13:39:38 - myDevices - INFO - History CalculateAverages increment: 79 2016-08-16 13:39:38 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {}} 2016-08-16 13:39:38 - myDevices - INFO - Save History Averages 2016-08-16 13:39:38 - myDevices - INFO - Memory usage : 85 size: 24396 2016-08-16 13:39:38 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=202.76, ru_stime=21.29, ru_maxrss=24396, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=749226, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=8296, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=100494, ru_nivcsw=34183) 2016-08-16 13:39:38 - myDevices - INFO - PacketTypes.PT_UTILIZATION 2016-08-16 13:39:57 - myDevices - INFO - SendHistoryData previously SendFailed items: [] 2016-08-16 13:40:08 - myDevices - INFO - History CalculateAverages increment: 80 2016-08-16 13:40:08 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {}} 2016-08-16 13:40:08 - myDevices - INFO - Save History Averages 2016-08-16 13:40:08 - myDevices - INFO - Memory usage : 86 size: 24404 2016-08-16 13:40:08 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=205.13, ru_stime=21.49, ru_maxrss=24404, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=757794, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=8376, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=101679, ru_nivcsw=34522) 2016-08-16 13:40:08 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:40:08 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:40:15 - myDevices - INFO - Checking for updates… 2016-08-16 13:40:18 - myDevices - INFO - Checking update version 2016-08-16 13:40:18 - myDevices - INFO - https://updates.mydevices.com/raspberry/update /etc/myDevices/updates/update 2016-08-16 13:40:19 - myDevices - INFO - Updater retrieve update success 2016-08-16 13:40:21 - myDevices - INFO - No new version detected. Closing update… 2016-08-16 13:40:38 - myDevices - INFO - ExecuteMessage: 4 2016-08-16 13:40:38 - myDevices - INFO - History CalculateAverages increment: 81 2016-08-16 13:40:38 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {}} 2016-08-16 13:40:38 - myDevices - INFO - Save History Averages 2016-08-16 13:40:38 - myDevices - INFO - Memory usage : 87 size: 24424 2016-08-16 13:40:38 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=207.23, ru_stime=21.73, ru_maxrss=24424, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=766936, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=8472, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=102742, ru_nivcsw=34857) 2016-08-16 13:40:38 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:40:38 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:40:38 - myDevices - INFO - PacketTypes.PT_UTILIZATION 2016-08-16 13:40:57 - myDevices - INFO - SendHistoryData previously SendFailed items: [] 2016-08-16 13:41:08 - myDevices - INFO - ExecuteMessage: 4 2016-08-16 13:41:08 - myDevices - INFO - History CalculateAverages increment: 82 2016-08-16 13:41:08 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {}} 2016-08-16 13:41:08 - myDevices - INFO - Save History Averages 2016-08-16 13:41:08 - myDevices - INFO - Memory usage : 88 size: 24444 2016-08-16 13:41:08 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=209.71, ru_stime=21.96, ru_maxrss=24444, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=775931, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=8552, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=103858, ru_nivcsw=35226) 2016-08-16 13:41:08 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:41:08 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:41:08 - myDevices - INFO - PacketTypes.PT_UTILIZATION 2016-08-16 13:41:38 - myDevices - INFO - ExecuteMessage: 4 2016-08-16 13:41:38 - myDevices - INFO - History CalculateAverages increment: 83 2016-08-16 13:41:38 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {}} 2016-08-16 13:41:38 - myDevices - INFO - Save History Averages 2016-08-16 13:41:38 - myDevices - INFO - Memory usage : 89 size: 24448 2016-08-16 13:41:38 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=211.9, ru_stime=22.18, ru_maxrss=24448, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=785051, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=8632, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=104971, ru_nivcsw=35617) 2016-08-16 13:41:38 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:41:38 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:41:38 - myDevices - INFO - PacketTypes.PT_UTILIZATION 2016-08-16 13:41:57 - myDevices - INFO - SendHistoryData previously SendFailed items: [] 2016-08-16 13:42:07 - myDevices - INFO - ExecuteMessage: 4 2016-08-16 13:42:08 - myDevices - INFO - History CalculateAverages increment: 84 2016-08-16 13:42:08 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {}} 2016-08-16 13:42:08 - myDevices - INFO - Save History Averages 2016-08-16 13:42:08 - myDevices - INFO - Memory usage : 90 size: 24448 2016-08-16 13:42:08 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=214.32, ru_stime=22.42, ru_maxrss=24448, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=794237, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=8712, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=106135, ru_nivcsw=35998) 2016-08-16 13:42:08 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:42:08 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:42:08 - myDevices - INFO - PacketTypes.PT_UTILIZATION 2016-08-16 13:42:38 - myDevices - INFO - ExecuteMessage: 4 2016-08-16 13:42:39 - myDevices - INFO - History CalculateAverages increment: 85 2016-08-16 13:42:39 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {}} 2016-08-16 13:42:39 - myDevices - INFO - Save History Averages 2016-08-16 13:42:39 - myDevices - INFO - Memory usage : 91 size: 24464 2016-08-16 13:42:39 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=217.28, ru_stime=22.83, ru_maxrss=24464, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=804886, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=8792, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=107451, ru_nivcsw=36693) 2016-08-16 13:42:39 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:42:39 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:42:39 - myDevices - INFO - PacketTypes.PT_UTILIZATION 2016-08-16 13:42:58 - myDevices - INFO - SendHistoryData previously SendFailed items: [] 2016-08-16 13:43:08 - myDevices - INFO - ExecuteMessage: 4 2016-08-16 13:43:08 - myDevices - INFO - History CalculateAverages increment: 86 2016-08-16 13:43:08 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {}} 2016-08-16 13:43:08 - myDevices - INFO - Save History Averages 2016-08-16 13:43:08 - myDevices - INFO - Memory usage : 92 size: 24464 2016-08-16 13:43:08 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=219.97, ru_stime=23.05, ru_maxrss=24464, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=814116, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=8880, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=108434, ru_nivcsw=37470) 2016-08-16 13:43:08 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:43:08 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:43:08 - myDevices - INFO - PacketTypes.PT_UTILIZATION 2016-08-16 13:43:38 - myDevices - INFO - ExecuteMessage: 4 2016-08-16 13:43:39 - myDevices - INFO - History CalculateAverages increment: 87 2016-08-16 13:43:39 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {}} 2016-08-16 13:43:39 - myDevices - INFO - Save History Averages 2016-08-16 13:43:39 - myDevices - INFO - Memory usage : 93 size: 24464 2016-08-16 13:43:39 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=222.5, ru_stime=23.25, ru_maxrss=24464, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=823303, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=8952, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=109609, ru_nivcsw=37888) 2016-08-16 13:43:39 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:43:39 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:43:39 - myDevices - INFO - PacketTypes.PT_UTILIZATION 2016-08-16 13:43:47 - myDevices - INFO - Checking for updates… 2016-08-16 13:43:50 - myDevices - INFO - Checking update version 2016-08-16 13:43:50 - myDevices - INFO - https://updates.mydevices.com/raspberry/update /etc/myDevices/updates/update 2016-08-16 13:43:51 - myDevices - INFO - Updater retrieve update success 2016-08-16 13:43:53 - myDevices - INFO - No new version detected. Closing update… 2016-08-16 13:43:58 - myDevices - INFO - SendHistoryData previously SendFailed items: [] 2016-08-16 13:44:08 - myDevices - INFO - ExecuteMessage: 4 2016-08-16 13:44:08 - myDevices - INFO - History CalculateAverages increment: 88 2016-08-16 13:44:08 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {}} 2016-08-16 13:44:08 - myDevices - INFO - Save History Averages 2016-08-16 13:44:08 - myDevices - INFO - Memory usage : 94 size: 24476 2016-08-16 13:44:08 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=224.79, ru_stime=23.59, ru_maxrss=24476, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=832253, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=9048, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=110729, ru_nivcsw=38336) 2016-08-16 13:44:08 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:44:08 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:44:08 - myDevices - INFO - PacketTypes.PT_UTILIZATION 2016-08-16 13:44:38 - myDevices - INFO - ExecuteMessage: 4 2016-08-16 13:44:39 - myDevices - INFO - History CalculateAverages increment: 89 2016-08-16 13:44:39 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {}} 2016-08-16 13:44:39 - myDevices - INFO - Save History Averages 2016-08-16 13:44:39 - myDevices - INFO - Memory usage : 95 size: 24484 2016-08-16 13:44:39 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=227.15, ru_stime=23.88, ru_maxrss=24484, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=841158, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=9128, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=111861, ru_nivcsw=38683) 2016-08-16 13:44:39 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:44:39 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:44:39 - myDevices - INFO - PacketTypes.PT_UTILIZATION 2016-08-16 13:44:58 - myDevices - INFO - SendHistoryData previously SendFailed items: [] 2016-08-16 13:45:08 - myDevices - INFO - ExecuteMessage: 4 2016-08-16 13:45:08 - myDevices - INFO - History CalculateAverages increment: 90 2016-08-16 13:45:08 - myDevices - INFO - Memory usage : 96 size: 24496 2016-08-16 13:45:08 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=229.54, ru_stime=24.23, ru_maxrss=24496, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=849826, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=9200, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=112886, ru_nivcsw=39018) 2016-08-16 13:45:08 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:45:08 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:45:08 - myDevices - INFO - PacketTypes.PT_UTILIZATION 2016-08-16 13:45:38 - myDevices - INFO - ExecuteMessage: 4 2016-08-16 13:45:38 - myDevices - INFO - History CalculateAverages increment: 91 2016-08-16 13:45:38 - myDevices - INFO - Memory usage : 97 size: 24500 2016-08-16 13:45:38 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=232.16, ru_stime=24.41, ru_maxrss=24500, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=859253, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=9280, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=114212, ru_nivcsw=39555) 2016-08-16 13:45:39 - myDevices - INFO - PacketTypes.PT_UTILIZATION 2016-08-16 13:45:58 - myDevices - INFO - SendHistoryData previously SendFailed items: [] 2016-08-16 13:46:08 - myDevices - INFO - History CalculateAverages increment: 92 2016-08-16 13:46:08 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {}} 2016-08-16 13:46:08 - myDevices - INFO - Save History Averages 2016-08-16 13:46:08 - myDevices - INFO - Memory usage : 98 size: 24500 2016-08-16 13:46:08 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=234.61, ru_stime=24.66, ru_maxrss=24500, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=868506, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=9368, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=115306, ru_nivcsw=39959) 2016-08-16 13:46:08 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:46:08 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:46:38 - myDevices - INFO - ExecuteMessage: 4 2016-08-16 13:46:38 - myDevices - INFO - History CalculateAverages increment: 93 2016-08-16 13:46:38 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {}} 2016-08-16 13:46:38 - myDevices - INFO - Save History Averages 2016-08-16 13:46:39 - myDevices - INFO - Memory usage : 99 size: 24508 2016-08-16 13:46:39 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=237.17, ru_stime=25.01, ru_maxrss=24508, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=877978, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=9456, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=116480, ru_nivcsw=40345) 2016-08-16 13:46:39 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:46:39 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:46:39 - myDevices - INFO - PacketTypes.PT_UTILIZATION 2016-08-16 13:46:58 - myDevices - INFO - SendHistoryData previously SendFailed items: [] 2016-08-16 13:47:08 - myDevices - INFO - ExecuteMessage: 4 2016-08-16 13:47:08 - myDevices - INFO - History CalculateAverages increment: 94 2016-08-16 13:47:08 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {}} 2016-08-16 13:47:08 - myDevices - INFO - Save History Averages 2016-08-16 13:47:08 - myDevices - INFO - Memory usage : 100 size: 24512 2016-08-16 13:47:08 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=239.58, ru_stime=25.24, ru_maxrss=24512, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=887318, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=9536, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=117678, ru_nivcsw=40636) 2016-08-16 13:47:08 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:47:08 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:47:09 - myDevices - INFO - PacketTypes.PT_UTILIZATION 2016-08-16 13:47:19 - myDevices - INFO - Checking for updates… 2016-08-16 13:47:22 - myDevices - INFO - Checking update version 2016-08-16 13:47:22 - myDevices - INFO - https://updates.mydevices.com/raspberry/update /etc/myDevices/updates/update 2016-08-16 13:47:23 - myDevices - INFO - Updater retrieve update success 2016-08-16 13:47:25 - myDevices - INFO - No new version detected. Closing update… 2016-08-16 13:47:38 - myDevices - INFO - ExecuteMessage: 4 2016-08-16 13:47:39 - myDevices - INFO - History CalculateAverages increment: 95 2016-08-16 13:47:39 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {}} 2016-08-16 13:47:39 - myDevices - INFO - Save History Averages 2016-08-16 13:47:39 - myDevices - INFO - Memory usage : 101 size: 24524 2016-08-16 13:47:39 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=241.95, ru_stime=25.49, ru_maxrss=24524, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=896658, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=9624, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=118744, ru_nivcsw=41020) 2016-08-16 13:47:39 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:47:39 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:47:39 - myDevices - INFO - PacketTypes.PT_UTILIZATION 2016-08-16 13:47:58 - myDevices - INFO - SendHistoryData previously SendFailed items: [] 2016-08-16 13:48:07 - myDevices - INFO - ExecuteMessage: 41 2016-08-16 13:48:07 - myDevices - INFO - PacketTypes.PT_UPDATE_SCHEDULES 2016-08-16 13:48:07 - myDevices - INFO - Schedules updated from cloud… 2016-08-16 13:48:08 - myDevices - INFO - ExecuteMessage: 4 2016-08-16 13:48:08 - myDevices - INFO - History CalculateAverages increment: 96 2016-08-16 13:48:08 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {}} 2016-08-16 13:48:08 - myDevices - INFO - Save History Averages 2016-08-16 13:48:08 - myDevices - INFO - Memory usage : 102 size: 24536 2016-08-16 13:48:08 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=244.14, ru_stime=25.67, ru_maxrss=24536, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=905971, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=9720, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=119953, ru_nivcsw=41351) 2016-08-16 13:48:08 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:48:09 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:48:09 - myDevices - INFO - PacketTypes.PT_UTILIZATION 2016-08-16 13:48:38 - myDevices - INFO - ExecuteMessage: 4 2016-08-16 13:48:39 - myDevices - INFO - History CalculateAverages increment: 97 2016-08-16 13:48:39 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {}} 2016-08-16 13:48:39 - myDevices - INFO - Save History Averages 2016-08-16 13:48:39 - myDevices - INFO - Memory usage : 103 size: 24540 2016-08-16 13:48:39 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=247.12, ru_stime=25.98, ru_maxrss=24540, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=916599, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=9808, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=121549, ru_nivcsw=41803) 2016-08-16 13:48:39 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:48:39 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:48:39 - myDevices - INFO - PacketTypes.PT_UTILIZATION 2016-08-16 13:48:58 - myDevices - INFO - SendHistoryData previously SendFailed items: [] 2016-08-16 13:49:08 - myDevices - INFO - ExecuteMessage: 4 2016-08-16 13:49:08 - myDevices - INFO - History CalculateAverages increment: 98 2016-08-16 13:49:08 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {}} 2016-08-16 13:49:08 - myDevices - INFO - Save History Averages 2016-08-16 13:49:08 - myDevices - INFO - Memory usage : 104 size: 24544 2016-08-16 13:49:08 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=249.65, ru_stime=26.17, ru_maxrss=24544, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=925949, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=9880, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=122591, ru_nivcsw=42307) 2016-08-16 13:49:08 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:49:09 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:49:09 - myDevices - INFO - PacketTypes.PT_UTILIZATION 2016-08-16 13:49:38 - myDevices - INFO - ExecuteMessage: 4 2016-08-16 13:49:39 - myDevices - INFO - History CalculateAverages increment: 99 2016-08-16 13:49:39 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {}} 2016-08-16 13:49:39 - myDevices - INFO - Save History Averages 2016-08-16 13:49:39 - myDevices - INFO - Memory usage : 105 size: 24560 2016-08-16 13:49:39 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=252.35, ru_stime=26.46, ru_maxrss=24560, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=935187, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=9960, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=123717, ru_nivcsw=42760) 2016-08-16 13:49:39 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:49:39 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:49:39 - myDevices - INFO - PacketTypes.PT_UTILIZATION 2016-08-16 13:49:58 - myDevices - INFO - SendHistoryData previously SendFailed items: [] 2016-08-16 13:50:08 - myDevices - INFO - ExecuteMessage: 4 2016-08-16 13:50:08 - myDevices - INFO - History CalculateAverages increment: 100 2016-08-16 13:50:08 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {}} 2016-08-16 13:50:08 - myDevices - INFO - Save History Averages 2016-08-16 13:50:08 - myDevices - INFO - Memory usage : 106 size: 24580 2016-08-16 13:50:08 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=254.79, ru_stime=26.67, ru_maxrss=24580, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=944417, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=10032, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=124827, ru_nivcsw=43174) 2016-08-16 13:50:08 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:50:09 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:50:09 - myDevices - INFO - PacketTypes.PT_UTILIZATION 2016-08-16 13:50:38 - myDevices - INFO - ExecuteMessage: 4 2016-08-16 13:50:38 - myDevices - INFO - History CalculateAverages increment: 101 2016-08-16 13:50:38 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {}} 2016-08-16 13:50:38 - myDevices - INFO - Save History Averages 2016-08-16 13:50:38 - myDevices - INFO - Memory usage : 107 size: 24580 2016-08-16 13:50:38 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=257.48, ru_stime=26.93, ru_maxrss=24580, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=953234, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=10120, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=125885, ru_nivcsw=43560) 2016-08-16 13:50:38 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:50:39 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:50:39 - myDevices - INFO - PacketTypes.PT_UTILIZATION 2016-08-16 13:50:51 - myDevices - INFO - Checking for updates… 2016-08-16 13:50:54 - myDevices - INFO - Checking update version 2016-08-16 13:50:54 - myDevices - INFO - https://updates.mydevices.com/raspberry/update /etc/myDevices/updates/update 2016-08-16 13:50:55 - myDevices - INFO - Updater retrieve update success 2016-08-16 13:50:57 - myDevices - INFO - No new version detected. Closing update… 2016-08-16 13:50:58 - myDevices - INFO - SendHistoryData previously SendFailed items: [] 2016-08-16 13:51:08 - myDevices - INFO - ExecuteMessage: 4 2016-08-16 13:51:08 - myDevices - INFO - History CalculateAverages increment: 102 2016-08-16 13:51:08 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {}} 2016-08-16 13:51:08 - myDevices - INFO - Save History Averages 2016-08-16 13:51:08 - myDevices - INFO - Memory usage : 108 size: 24592 2016-08-16 13:51:08 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=259.88, ru_stime=27.15, ru_maxrss=24592, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=961708, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=10200, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=126938, ru_nivcsw=43943) 2016-08-16 13:51:08 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:51:09 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:51:09 - myDevices - INFO - PacketTypes.PT_UTILIZATION 2016-08-16 13:51:29 - myDevices - INFO - ExecuteMessage: 37 2016-08-16 13:51:29 - myDevices - INFO - Skipping not required packet: 37 2016-08-16 13:51:38 - myDevices - INFO - ExecuteMessage: 4 2016-08-16 13:51:39 - myDevices - INFO - History CalculateAverages increment: 103 2016-08-16 13:51:39 - myDevices - INFO - Memory usage : 109 size: 24592 2016-08-16 13:51:39 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=262.39, ru_stime=27.4, ru_maxrss=24592, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=971074, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=10280, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=128112, ru_nivcsw=44363) 2016-08-16 13:51:39 - myDevices - INFO - PacketTypes.PT_UTILIZATION 2016-08-16 13:51:58 - myDevices - INFO - SendHistoryData previously SendFailed items: [] 2016-08-16 13:52:08 - myDevices - INFO - History CalculateAverages increment: 104 2016-08-16 13:52:08 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {}} 2016-08-16 13:52:08 - myDevices - INFO - Save History Averages 2016-08-16 13:52:08 - myDevices - INFO - Memory usage : 110 size: 24596 2016-08-16 13:52:08 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=264.9, ru_stime=27.63, ru_maxrss=24596, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=979753, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=10360, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=129213, ru_nivcsw=44725) 2016-08-16 13:52:08 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:52:09 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:52:38 - myDevices - INFO - ExecuteMessage: 4 2016-08-16 13:52:39 - myDevices - INFO - History CalculateAverages increment: 105 2016-08-16 13:52:39 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {}} 2016-08-16 13:52:39 - myDevices - INFO - Save History Averages 2016-08-16 13:52:39 - myDevices - INFO - Memory usage : 111 size: 24612 2016-08-16 13:52:39 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=267.5, ru_stime=27.97, ru_maxrss=24612, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=989071, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=10440, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=130327, ru_nivcsw=45217) 2016-08-16 13:52:39 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:52:39 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:52:39 - myDevices - INFO - PacketTypes.PT_UTILIZATION 2016-08-16 13:52:58 - myDevices - INFO - SendHistoryData previously SendFailed items: [] 2016-08-16 13:53:08 - myDevices - INFO - ExecuteMessage: 4 2016-08-16 13:53:09 - myDevices - INFO - History CalculateAverages increment: 106 2016-08-16 13:53:09 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {}} 2016-08-16 13:53:09 - myDevices - INFO - Save History Averages 2016-08-16 13:53:09 - myDevices - INFO - Memory usage : 112 size: 24628 2016-08-16 13:53:09 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=270.19, ru_stime=28.13, ru_maxrss=24628, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=998904, ru_majflt=39, ru_nswap=0, ru_inblock=18152, ru_oublock=10520, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=131675, ru_nivcsw=45545) 2016-08-16 13:53:09 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO 2016-08-16 13:53:09 - myDevices - INFO - ExecuteMessage: 3 2016-08-16 13:53:09 - myDevices - INFO - PacketTypes.PT_UTILIZATION pi@raspberrypi:~ $
Simon Woodhead
