Bug Filed on 12-11-2015: Whoops I've broken the dashboard continued
Continuing the discussion from Bug Filed on 12-07-2015: Whoops I've broken the dashboard:
I wanted to Reply to this topic but no usual Reply button … had to —> “Reply as linked Topic” which is going to Create a new Topic, what’s that about ? (this is getting quite tedious)
Regarding “We deployed another fix” what is the correct method to use this fix, if I log on to the dashboard I can see that the Reset button has gone, but I still have the multiple widgets. I am going to try to do a reinstall but it would be usefully to know how you expect this / any fix to be applied.
I deleted the pi from the dashboard using Remove Device then re-installed
wget https://cayenne.mydevices.com/rpi/rpi_nm2zodepej.sh
sudo sh rpi_nm2zodepej.sh
Rebooted the pi, logged on to the dashboard absolutely no change, I still have multiple widgets.
So shutdown pi, did a fresh install of wheezy … re-installed mydevices again … reboot … logged on to the dashboard absolutely no change, I still have ******* multiple widgets.
Conclusion for me to go on you need to reset something at your end because I just cannot get ride of this issue of multiple widgets.
Toshi
Hey Toshi,
Should be good now, or at least have a way to reset it.
Keep trying to break it though :grin: and let us know if you do.
-Benny
