I notice that my SD Card becomes full in few hours…
That’s why i found some log file in /var/log, called myDevices.log.(date)…
i need to erase all this file otherwise my Rpi dont work…
As you can see in attached screenshot,
in yellow rectangle SD situation before remove…
in blue rectangle 4 file in object
in red rectangle file removed
in white rectangel situatione after removing that file…
Just checking but…
Did you choose option 1 in sudo raspi-config from the command line menu ?
This is like aka the Pi BIOS Settings to expand the file system to maximise the available real estate on the SD card ?
I think I heard Pi default OS assumes there is just 4G total. I am Not an expert on this…
Try it and see what the difference is or if it fixes things ?
This could be an auto set-up feature ?
~ Andrew
sudo raspi-config
Option 1
Exit and choose re-boot
While you are at it make sure you have all the penguins up to date and in a row… sudo apt-get update sudo apt-get upgrade
Choose Y
Come back in 15 minutes
reboot etc
This should be included in the ‘setting up your hardware’ part of the manual or tutorial etc.
We should no longer be storing logs on your Pi. @ftvplant Let me know if expanding the file system resolves issue. Also, think you could email me your login information so we can ‘look under the hood’?
@akaranfilian Let’s see what happens when we don’t expand the file system and use myDevices Cayenne.
Ah, yes sorry I missed the fist column which is your total size. I usually use df -h so that format is a little different than what I am used to. If you have no need for logs you can set up a cron job to delete all log files every hour until this is fixed.
First switch to root user to avoid permission issues: sudo su
Then create the cron job: crontab -l | { cat; echo “0 * * * * rm /var/log/myDevices.log*”; } | crontab -
After that type in exit to get back to your regular pi account and you’re good to go.
To delete the cron job switch back to the root account with sudo su and use the command crontab -e then delete the line we added and save it.
